| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
04-06-2004, 05:18 PM
#31
Re: LT1 vs. LS1???
Originally Posted by z06transam
Ls1 Definately Kicks Ass Ove Rthe Ls1. So Uch More Power And Overall Stronger Engine.
Umm...LS1s kiss ass over the LS1?
El Tee Juan(LT1 for the non-ricers) cars are just as good as Ellis Juan(LS1) cars. Engines are just a little different on how they make power. The fastest 4th Gen Fbody is an LT1.
I hate this LT1/LS1 BS that is going on between 4th Gen owners. Just be glad you're not driving a Ford
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
04-06-2004, 08:01 PM
#32
Most Seniorest Mod EVER!
Re: LT1 vs. LS1???
To tell you the truth I like the LT1 VS LS1 owner BS, It makes me go that much farther to make my car the car that the LS1 owner states my car is not and while the LS1 is a more efficient engine out the box with the aftermarket's help the LT1 has unlimited potential and without competition we don't try as hard for perfection
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
04-06-2004, 09:06 PM
#33
I have had two LT1s (93 & 95) and two LS1s (99 & 2002) in the past 11 years. Both of my LS1s developed piston slap when I take off from a cold start in the morning (or whenever). They are fine when they warm up, but cold is not good.
I even had to have some corrosive stuff sit in the cylinders overnight to remove the carbon deposits on the top of the pistons to try to reduce the piston slap. That is their cheep way to get around a recall (it worked, but it seems like something that you should not have to do at 30K miles). My newest one (8K miles) has it already and I am bracing myself for more wrangling at the dealership. Never had a problem with my LT1s, they were rock solid.
When they did the upgrade to the LS1, they also changed the transmission and the rear axle to have an electronic controller(s) and that is why the “performance transmission” button went away (again LT1 wins, I liked the button!).
Don’t get me wrong I love my LS1, but it seems a little less tired and true then the LT1.
F-Bodies Rule!!!!
Jeff
04-06-2004, 11:22 PM
#34
Re: Re: LT1 vs. LS1???
I understand that. Its all in good clean fun when its between friends, but sometimes on other boards, the LT1/LS1 arguement gets WAY out of hand which is what I can't stand.
DarkblueTA
04-06-2004, 11:28 PM
#35
Re: LT1 vs. LS1???
yeah, Ellis has some issues. the piston slap that you hear is normal on the LS1 cars. As is a little oil eating problem(blame the smart guy who designed the PVC system)....but that's what catch cans are for  (if you don't know what I'm talking about, ask me and I'll show you).
If you're oil consumption is really bad...have the dealership put you on a scheduled oil consumption test. I wish I still had the paperwork(its lost in my stuff packed up in Lancaster PA and I'm out here in Las Vegas NV) but it was a recall on any of 01 and 02 cars that had excessive oil consumption because the #1 cylinder was overbored. Solution was that they had to tear down the engine and replace the piston and rings.
I have a very slight piston slap on my 98..but only if its really cold outside(talking 30s and lower).
Either way, both engines are great. I <3 4th Gen Fbodies.
DarkblueTA
04-06-2004, 11:31 PM
#36
Re: LT1 vs. LS1???
The one rule that everyone has to remember is that your never going be the fastest and that everyone should show respect to get respect and it would never get out of hand and I would never try so hard to take down my LS1 brother's if I didn't have so much respect for them
04-06-2004, 11:36 PM
#37
And I agree. I enjoy and respect the LT1. I almost bought a 97 LT1 Camaro, but I found this 98 LS1 at a better price. Its all in good fun to me anyways. So its all good. What mods do you have done to your car?
DarkblueTA
04-06-2004, 11:42 PM
#38
Re: LT1 vs. LS1???
Hooker Long tubes, Borla Catbacks, Accel 300 ignition, 3.73's gears, Transgo shift kit, corvette servo, lt4 KM, IAT relocator , TB bypass ,K&N CAI, Airfoil, PCM tuning and I'm sure I'm forgetting stuff
04-06-2004, 11:47 PM
#39
Re: LT1 vs. LS1???
Oh yeah 160 Temp thermostat and 1LE elbow
04-06-2004, 11:49 PM
#40
Re: LT1 vs. LS1???
can you get a shift kit for an automatic 98 trans am ls1?. Oh and is a piston slap somthing i would hear or feel? i never had anything like that,that i know of on my TA and it has 54k miles what is it?
04-06-2004, 11:51 PM
#41
Re: LT1 vs. LS1???
You need programming before you can install a Transgo and piston slap is something you should only be concerned about in winter and yes you will notice it , if you had it
04-06-2004, 11:56 PM
#42
Re: LT1 vs. LS1???
ok well i just ordered hypertech 3 power programer along with 160 thermo will be here tomorrow actually  and also getting 3.73's installed on friday. besdies that got catbacks. is the shift kit very beneficial could i get it after the programmer? Also what else do you suggest i do next after those mods to my ls1
04-07-2004, 12:05 AM
#43
Re: LT1 vs. LS1???
Nothing now I'm pissed , I say you never install the mods so I can still beat you! and the shift kit is great as long as you do the install with the higher performance setting's(they give you options on which springs to use and how many washer's) and I don't think you can program for a Transgo with a power programmer but I could be wrong your best bet is to call transgo to find out
#44
I don't know what you are talking about please do show me.
I do know that my 2002 has piston slap at 8K miles and it took 30K for my 1999 to get there. I have not had it enough to know if it is loosing or burning oil (I don't think that it is leaking).
Now you have me concerned. Can you give me more info on this?
Thanks,
Jeff
04-09-2004, 12:51 AM
#45
Re: Re: Re: LT1 vs. LS1???
Thanks,
Jeff
Jeff...no problem. tomorrow AM, I will take a picture of my catch can on my car so you can see. They are about 20.00 at home depot. They are really moisture canisters for the air compressors. Just add them in your PVC lines. I have one on the line going from the valve cover to my blower inlet hat(on your car it would go to the throttle body). I will install a 2nd catch can from the valve cover to the intake. All LS1s burn a little bit of oil, especially if you don't have the catch cans(basically, they catch any oil that might make it into your intake then engine). Oil in the combustion chamber mixing with the air/fuel ratio is not a good thing for power output. If you are worried about your engine eating oil, keep an eye on it and if it goes down really fast, have your car put on an oil consumption test at the dealer. if it fails the test('eats' to much oil), they will replace the #1 Piston and rings for you.
I think I posted up on here before about the overbore on #1 cylinder. As long as your are not burning crazy amounts of oil, don't sweat it to much. Just make sure you don't use more then a quart between oil changes. Piston slap is really noticeable if you have it. I hear just a very little bit if its really cold outside. other then that, I don't hear it.
Shoot me an email at darkblueta@aol.com and I'll email you back the picture of one installed.
DarkblueTA
