Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > How-to/Technical Info
How-to/Technical Info A wealth of information at your disposal.
Thread Tools Search this Thread
Old 10-30-2008, 05:29 PM   #46
authoriti
authoriti Normal reputation
Re: Fuel Injector/spider How To
I'm going to be replacing my old spider with a new upgraded module (used). The part that concerned me is that the new module doesn't seem to use the same style connector for the lower manifold. It's just a white tube. On my old 96 that I did the injector connectors were black with a tooth like structure on the tip to hold them on. I haven't had time to see if there is a ridge on the inside of the new one though. Is this normal or did I get a unit that is missing parts?
Thank you.
authoriti is offline   Reply With Quote
Old 08-21-2009, 07:42 PM   #47
zaxx0n
zaxx0n Normal reputation
I'am having problem with 1 of my spider lines keeps "clogging" up, I've used fuel injector cleaner, seems to not be helping. I been searching on how to get to them and try to do it myself since mech charges me 300 to 400 bucks each time i take it back for this problem (3 time in 2yrs). Is doing this very hard to do? or is there way to just let it run and put more fuel injector cleaner in it hoping maybe it will clear up...? or any other ideas anyone has.
thx.
zaxx0n is offline   Reply With Quote
Old 10-08-2009, 12:15 PM   #48
Rottwiener
Rottwiener Normal reputation
Is there an updated thread for this topic?
It appears that GM Parts Direct has changed the contents of the MFI kit. The current listing for pk12568332 includes the bracket and the seal kit, but does not include the regulator. I'd like to do this mod, but am woried about not getting all of the right parts. Any help?
Thanks,
Jeff
Rottwiener is offline   Reply With Quote
Old 10-22-2009, 02:02 PM   #49
laxman21
laxman21's Avatar
laxman21 Normal reputation
get it off ebay....much cheaper. My V-8 was $225 and the V-6 is about the same.
AC Delco
Adelphi
Borg-warner
They are all the same made by the same people.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
laxman21 is offline   Reply With Quote
Old 10-25-2009, 10:03 PM   #50
krackerjack9
krackerjack9 Normal reputation
Smile Re: Fuel Injector/spider How To
I just replaced my CPI spider assembly in my 92 S-10 blazer. I had 273,441 miles on it. About 2years ago I thought I was going to be replaced but turned out that fuel regulator was leaking. The past 2 months my milage was down to 17 mpg from 23/24. Took me about a little over a hour and half to take out the old one and put in the new one. Used about 2 cans of engine degreaser on the uppper intake and the lower intake. Man that was just flat out nasty carbon mess!!! Any way took about 3 cranks and about minute of reving it to clear out all the engine and carb cleaner that was remaning in the ports im guessing. Drove into town and it was just smooth no more rough idling and most of all NO Service Engine Light!!!! Will post my fuel milage latter after I run 2 tanks thur it. I drive 27 miles one way to work and only 2 stop signs and 2 traffic lights to go thur so its a good 98% highway miles. Got CPI unit from Autowharehouse for 189.89 send in my old unit and it comes out to 159 and some change. Tools needed a 7mm socked, 10mm long socket, one straight slot screwdriver and one Torx bit cant remember size and that was it.
krackerjack9 is offline   Reply With Quote
Old 10-29-2009, 06:36 AM   #51
krackerjack9
I couldnt wait till I hit around 240-250 miles I filled up at 153 miles and it took 6.73 for a mpg of 22.7 miles per gallon. Im sure it will go over 23 maybe 24 once I change out the oil and put in some new spark plugs.
Old 11-21-2009, 09:31 PM   #52
socialvictim
socialvictim Normal reputation
I just wanted to say thanks for this awesome write-up. It was very helpful and informative. I recently replace my fuel spider in my '99 Jimmy. It was getting to where it was very hard to start regardless of temp. I replace the spider and now it fires up better than when we purchased a couple of years ago. I am still getting pretty lame fuel mileage. But I am hoping to learn from this site on how to fix that though.
socialvictim is offline   Reply With Quote
Old 11-21-2009, 10:34 PM   #53
krackerjack9
Up date everything is still great milage is constinatly around 23.2 mpg.
I did up my air pressure a bit to 38psi and had frontend aligned along with some new goodyear tires, I needed some tires. I checked my plugs last week and everyone of them looks like a perfect burn pattern. Other than that im extreemly pleased on results. So if I get another 5 years out of my 92 Blazer I will be more than happy. The only thing I could see going wrong is the transmission. So far no signs of anything going wrong,but I ocassionally tow my Kubota L4400 with frontend loader and Rhion 172 brush shredder. Wieght is im guessing around 5500lbs. Im on back roads and dont go over 50mph.
Bookmarks
Search this Thread:
Google
Web AF
