Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 04-27-2006, 09:26 PM   #16
ysteve
ysteve Normal reputation
Re: Question for everybody(MAF)
I dont understand what you saying about Maf sensor. Bnaylor3400 saying if maf was bad your rpm gonna drop, which i dont have. Maybe Maf is fine but take a look on this. I have everithing exept SES light.
A/T - Shift/Driveability Concerns/SES Lamp ON
Bulletin No.: 04-07-30-013A
Date: January 25, 2005
INFORMATION
Subject:
Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Use of an Excessively/Over-Oiled Aftermarket, Reusable Air Filter
Models:
2005 and Prior GM Cars and Light Duty Trucks
2005 and Prior Saturn Models
Supercede:
This bulletin is being revised to add additional model years and to clarify warranty coverage. Please discard Corporate Bulletin Number 04-07-30-013 (Section 07 - Transmission/Transaxle).
The use of an excessively/over-oiled aftermarket, reusable air filter may result in:
^Service Engine Soon (SES) Light On
^Transmission shift concerns, slipping and damaged clutch(es) or band(s)
^Engine driveability concerns, poor acceleration from a stop, limited engine RPM range
The oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur.
When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively/over-oiled air filter. The MAF, GPS reading should be compared to a like vehicle with an OEM air box and filter under the same driving conditions to verify the concern.
The use of an aftermarket reusable air filter DOES NOT void the vehicle's warranty.
If an aftermarket reusable air filter is used, technicians should inspect the MAF sensor element and the air induction hose for contamination of oil prior to making warranty repairs.
Transmission or engine driveability concerns (related to the MAF sensor being contaminated with oil) that are the result of the use of an aftermarket reusable, excessively/over-oiled air filter are not considered to be warrantable repair items.
ysteve is offline   Reply With Quote
Old 04-28-2006, 09:07 AM   #17
BNaylor
BNaylor's Avatar
BNaylor +50
INFORMATION
Subject:
Models:
Supercede:
If you do not have any symptoms of a bad MAF sensor, then your MAF sensor is probably OK. The above refers to using aftermarket oiled air filters like K&N drop in or cone filter like on a CAI/FWI.
Are you using an aftermarket oiled air filter? The MAF sensor can be cleaned with MAF sensor spray cleaner (Gunk brand) if you suspect contamination. The MAF sensor on a 3.4L is very easy to clean or replace.
'08 Pontiac Grand Prix GXP (Liquid Silver Metallic) - LS4 5.3L V8
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 04-28-2006, 08:32 PM   #18
ysteve
First. Where i can get that maf cleaner.?
Second, i have hard shifting and major loss of power(and plus when accelerating noise looks like valves ticking). Ihave everithing like maf sensor bulletein saying exept SES light. (today was chaged another set of wires)
I am tired of spending money. Maybe you can think something else.
Thank you so much, looks like you have big expirence.
Another thing, how i can check coils?
Old 04-29-2006, 07:57 AM   #19
BNaylor
BNaylor's Avatar
BNaylor +50
I got my MAF cleaner from Autozone. Its in a gray can with the Gunk label.
If you have a mulitmeter you can check the resistance of the coil primaries and see if in spec. per the service manual. Also, under the coils is an Ignition Control Module (ICM). I've had the ICM tested at Autozone for free.
Timeslip 08/12/06
Old 04-29-2006, 05:22 PM   #20
ysteve
Thank you Bnaylor3400 i clean the MAF sensor and still the same thing, And plus today guys from strauss cleand my injectors thru the intake. So looks like i dont have mechanical problem. Probably electrical. About coils i mesured with ohms and kohms and it showed me 0. i dont know why there no resistance owethere.
Old 04-30-2006, 11:06 AM   #21
BNaylor
BNaylor's Avatar
BNaylor +50
The proper values are in the respective GM service manual. Off the top of my head primary resistance is around 0 - 2 ohms. Secondary coil resistance around 5K - 8K ohms.
Didn't you mention earlier that you could hear the engine knocking or rattling like possibly pre-ignition or detonation? You are aware there are two knock sensors that feed knock data to the PCM module. If bad they should trigger a SES/CEL light but not always. One is located right by the oil filter on the side of the engine towards the radiator and the other on the back side of the engine block. The knock sensor(s) will retard ignition timing and reduce power when detonation is detected. Thats about all I can think of for now.
Timeslip 08/12/06
Old 05-01-2006, 07:16 AM   #22
billyo69
billyo69 Normal reputation
Originally Posted by JJ Newel
WAIT what about using a hair dryer?
WD 40 or rust eater dripping into the motor will not hurt anything.It may help you get the plugs out although they should come out with no problem.I put a little never-sieze on plugs when i put them in.People also use WD 40 as starting fluid on diesel engines.
billyo69 is offline   Reply With Quote
Old 05-01-2006, 08:13 AM   #23
Gems
Gems Normal reputation
Has the original poster in this thread checked for a clogged Catalytic Converter yet?... I had some of the symptoms he is describing until I finally had the CAT replaced... Now the car runs like a rocket!...
Go Mark Martin!
Gems is offline   Reply With Quote
Old 05-01-2006, 08:38 AM   #24
BNaylor
BNaylor's Avatar
BNaylor +50
I believe he has. Replaced with an aftermarket direct fit. He's had other posts on the same issue.
A new CAT does wonders if thats the problem.
Timeslip 08/12/06
Old 05-01-2006, 07:34 PM   #25
ysteve
Hi bnaylor3400 i so pissed right now, i just from dealer he check this freaking car and saying everithing is ok, but i am not stupid tha car runs like crap. He sayd computer couldnt find nothing. I wanna ask you 2 questions , first about oil pressure how can i check that, cause maybe before i put syntetic and something wrong with pump, maybe on top not enough oil i mean loosing compression wich causing missfire. Because all this problem(loss of power, kickback upshifting and noise looks like valves) start when i start changing stuff. And another question what is firing order. I mean when you open the hood from left to right i have this coil location 5and2, 3and6, 1and4. Is this rigth just i case, maybe sombody before reverse it. Thank you so much guys.
I still cant belive those idiots charge me 113$ for diagnose and find nothing.
One more thing, satturday i had conversation with couple of mechanics, and he put his hand on exaust mufler pipe and gases dosent coming out smooth, and he sayd thats misfire and if no SES light then this problem is gonna be hard to find. He sayd method illumination. So if this method then look at this guys(was changed): CAT, fuel and air filter, plugs and wires two times, maf was cleaned, injectors was cleand 2 times, coils is fine (6,38-6,40 kohms),fuel pressure 52-54psi, sometimes having DTC P0420 but like forum saying(dont worry about it).
I dont know what else it could be, but i am really not happy with GM.
Old 05-01-2006, 08:34 PM   #26
BNaylor
BNaylor's Avatar
BNaylor +50
The coil pack order looks correct if you are looking at it from the front of the engine looking in.
If the oil pressure was not good you would have a Oil Warning Light. The sending unit is located by the oil filter. Unless you have an oil pressure gauge in the IP to check actual oil pressure you'd have install an aftermarket oil pressure gauge for troubleshooting purposes.
Have you considered running a compression check of all 6 cylinders. The gauge doesn't cost that much. If nothing is showing up at the dealer or on a Tech II the maybe you have an internal engine problem.
Timeslip 08/12/06
Old 05-01-2006, 08:46 PM   #27
ysteve
How i can check compression by my self, cause alldata showing whole history(you have to disconnect pcm bla bla bla). And where i can get gage. Maybe something wrong with the valves( not closing proberly). And plus its maybe you know what: i have direct fit cat (aftermarket) and metal is very thin, so you can hear all the noises. Thats another opinion. Look at this , this looks to me hard to check alone.
Testing and Inspection
Engine Compression Test
A compression pressure test of the engine cylinders determines the condition of the rings, the valves, and the head gasket.
Important: Remove the Powertrain Control Module (PCM) and the ignition fuses from the I/P fuse block.
  1. Disable the ignition.
  2. Disable the fuel systems.
  3. Remove the spark plugs from all the cylinders.
  4. Remove the air duct from the throttle body.
  5. Block the throttle plate in the open position.
  6. Measure the engine compression, using the following procedure:
6.1.Firmly install the compression gauge to the spark plug hole.6.2.Have an assistant crank the engine through at least 4 compression strokes in the testing cylinder.6.3.Record the readings on the gauge at each stroke.6.4.Disconnect the gauge.6.5.Repeat the compression test for each cylinder.
  1. Record the compression readings from ail of the cylinders. The lowest reading should not be less than 70 percent of the highest reading.
    • No cylinder reading should be less than 689 kPa (100 psi)
  1. The following list contains examples of the possible measurements:
    • When the compression measurement is normal, the compression builds up quickly and evenly to the specified compression on each cylinder.
    • When the compression is low on the first stroke and tends to build up on the following strokes, but does not reach the normal compression, the piston rings may be the cause.
    • If the compression improves considerably with the addition of three squirts of oil, the piston rings may be the cause.
    • When the compression is low on the first stroke and does not build up in the following strokes. the valves may be the cause.
    • The addition of oil does not affect the compression, the valves may be the cause
    • When the compression is low on two adjacent cylinders, or coolant is present in the crankcase, the head gasket may be the cause.
  1. Remove the block from the throttle plate.
  2. Install the air duct to the throttle body.
  3. Install the spark plugs.
  4. Install the Powertrain Control Module (PCM) fuse
  5. Install the ignition fuse to the I/P fuse block
Old 05-03-2006, 07:43 AM   #28
BNaylor
BNaylor's Avatar
BNaylor +50
You'll need a second person. One will have to hold the compression tester and the other will crank the engine over. The gauge is available at places like Autozone.
To disable the ignition you can pull the PCM fuse and to disable fuel system pull the fuel pump fuse.
Although it specifies nothing less than 100 psi good compression is typically around 125 - 140 psi on a 3.4L. Also all six spark plugs should be removed before running test.
Timeslip 08/12/06
Old 05-09-2006, 09:09 PM   #29
ysteve
Hi bnaylor3400 , so i never got a chance to check compression. And still think there is nothing wrong witn compression. Look what i just remember, when i got this car 7 mount ago, next couple of weeks i had (sometimes) hard starting and electrical burning smell, sure you gonna think (this is rubber smell and this is cat), but no this was electrical smell. And after maybe 2-3 weeks it finished. So maybe i have some electrical problem? I couldnt find anything, but smell was from driver side somewhere, from fuse box(deeper) or around PCM. There wasnt any SES. If you think i still have to check compression, wich i think i have sheety after market CAT with thin metal, so you can hear everething. So, brother i still have this hard shifting and feels like missire(cause engine i shaking(detonating)), but i wondering why i dont have SES light.
And another question i found on ALLDATA all solenoids(tranny) resistance wich i can check with tester thru the pins, what you think if it was something wrong solenoids it should throw me the code, right? So if no tranny code, then no tranny problem. And those dealers cant find anything cause they using that stupid tech2. What else you think can give missfire or hard shifting without SES light.
Cause guys on two reply down with "impala power" saying about spining tires, then i think i can make it smoke(when TRACTION OFF) so we 1 problem less, iam about low power.
Any info thankfull.
Old 05-11-2006, 08:23 AM   #30
BNaylor
BNaylor's Avatar
BNaylor +50
I'm just about all out of suggestions. On the tranny I would assume a code would be triggered. Some tranny error codes do not generate a SES light but a good scanner should pick up any possible stored codes.
If you noticed a smell of burnt electrical or wiring I would do a closer inspection. Especially the wiring harness going to the PCM module and the Ignition Control Module. There are two wires, red and orange which supply 12 volts to the PCM from the battery and ignition control circuits. I've seen these wires damaged from a simple jump start or bad charging system problem. Also, in the same wiring harness and to the PCM 80 pin connector I'd check the lines for the ignition control module Bypass and PC mode operation. If stuck in bypass it will give misfires, however, an error code of P300 along with P1361 & 1362 are normally stored.
Other than that
Timeslip 08/12/06
Bookmarks
Google
Web AF
