Originally Posted by ysteve
No iam not loosing any coolant. I think owner before fix gasket. About spark plug and wires acdelco (brandnew). (fuel and air filter new as well, pcv, cat)
The symptoms is like engine cant breath, like cloged cat. But i put Direct Fit, maybe aftermarket one but this dosent metter. Only thing i newer changed its o2 sensors.
How i can check injectors for carbon. Cause when car is hot i feel little vibration(onthe neutral), dosent idlle smooth (no codes of misfire)
Ok I guess we can rule that out.
Have you tried running any fuel injector cleaner like Lucas through the gas tank?
02 sensor is a possibiity but I doubt it. When accelerating or when power is needed the PCM is in open loop mode which means the 02 sensors are out of the picture (inhibited). They are used at idle after engine warms up to proper operating temperature, cruising, etc. Closed loop mode only.
On the 3.4 you can manually clean injectors by removing the throttle body and upper intake manifold plus anthing else in the way like electrical connecors and vacuum lines. Then you remove each fuel injector rail with the injectors intact. You can leave the fuel supply pressure and return lines connected to the rail or disconnect them. However, once injector is pulled you should put in new o-rings.
Have you checked out the EGR valve and tried cleaning it and make sure passages from exhaust to UIM are not carboned up. Make sure EGR spring loaded pintle is clean and moves freely. Spray pintle with WD40. An EGR valve stuck open could cause loss of power and rough idle. Doesn't always give an error code or SES light either.
Good luck!
