Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 03-13-2006, 06:20 PM   #16
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: 2000 Blazer LS Vibration Problem
While they are balancing your tires, have them check them for out of round too. EXAGERATED EXAMPLE: If a tire is oval shape, they can still balance it perfectly, now roll it and see what happens!
old_master is offline
Old 03-14-2006, 01:57 PM   #17
swalt
swalt's Avatar
swalt Normal reputation
Does the problem occur in both 2HI and 4HI,or does it disappear in 4WD?
swalt is offline
Old 03-14-2006, 06:37 PM   #18
jaxondes
jaxondes Normal reputation
Mine doesn't change whether I'm in 4 HI, 2 HI or Autotrac
jaxondes is offline
Old 03-14-2006, 09:56 PM   #19
BlazinMlew
BlazinMlew's Avatar
BlazinMlew Normal reputation
Send a message via Yahoo to BlazinMlew
will a ball joint really cause that much vibration??? Cause if so I really need to get mine changed.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
BlazinMlew is offline
Old 03-14-2006, 10:12 PM   #20
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Guys, not meaning to be insistent, but don't start dabbling with your suspension until you have properly re-balanced the wheels.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline
Old 03-14-2006, 10:22 PM   #21
old_master
Advisor/Moderator
old_master's Avatar
It is possible for worn ball joints to cause a shimmy after going over bumps, but only if they, and the shocks, are extremely worn. As far as causing a vibration, you're barking up the wrong tree... absolutely not.
Old 04-27-2007, 01:48 PM   #22
DRGREENTHUMB1001
DRGREENTHUMB1001
If all else fails take Billibongs advice. For some reason I have re-curring problems with my passenger side ball joints, except on the right side it wears the outside of my tire, but if you are having a front end alignment done make sure they check the ball joints, tire rods, etc. Thay would and should tell you if anything in the front suspension needs to be replaced. If it is the ball joints, you can do it yourself, but you will need some loaner tools from Auto Zone, specifically a 36mm axle nut socket to take the bearing off the axle shaft, a torque wrench to put the nut back on, and a two prong fork to pop out the old ball joints(I forget the exact name of it, sorry) I'm sure there are directions to do the job somewhere on this site, if not, go to Auto Zones site.
PS Buy NAPA balljoints better quality than the rest.
DRGREENTHUMB1001 is offline
Old 04-27-2007, 02:36 PM   #23
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
ZL1power69 Normal reputation
Send a message via AIM to ZL1power69
this thread is now over a year old. please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance: AEM intake, TB mod, ported stock y-pipe w/precat deleted, 3in catco cat, 2.5in Flowmaster 40 DF,
March pulleys, MSD SF ignition, Taylor 8.2 wires, Transgo shift kit, Corvette servos, B&M trans cooler.
Suspension: Knaffle 1.5in lift shackles, 1.25in rear wheel spacers, 31in BFG AT's
Exterior: custom ZR2 decals, bug guard, vent visors
Interior: Lanzar headunit w/ ipod input, Pioneer speakers, Scanguage II
http://www.cardomain.com/ride/3013891
ZL1power69 is offline
Closed Thread
Bookmarks
Google
Web AF
