Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-23-2006, 04:10 PM   #76
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
ZL1power69 Normal reputation
Send a message via AIM to ZL1power69
Re: Throttle plate mod
Originally Posted by agcneo
i did the mod, and it sounds simple. but honestly it seems like a loss of power, it hesitates now untill it hits higher rpms. did i do something wrong??! i have only put 50 miles on since i did it. do i have to wait for the long term memory in the ecu to reprogram itself?
the only thing u can do wrong is to mess with the hole and rivits in the plate. if you just ground the half moon shaped piece off, you should not notice a loss of power. the computer will relearn fairly quickly but when i did the mod, i reset the computer with a scan tool.
2000 Chevy Blazer ZR2
Performance: AEM intake, TB mod, ported stock y-pipe w/precat deleted, 3in catco cat, 2.5in Flowmaster 40 DF,
March pulleys, MSD SF ignition, Taylor 8.2 wires, Transgo shift kit, Corvette servos, B&M trans cooler.
Suspension: Knaffle 1.5in lift shackles, 1.25in rear wheel spacers, 31in BFG AT's
Exterior: custom ZR2 decals, bug guard, vent visors
Interior: Lanzar headunit w/ ipod input, Pioneer speakers, Scanguage II
http://www.cardomain.com/ride/3013891
ZL1power69 is offline   Reply With Quote
Old 11-25-2006, 05:04 AM   #77
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
A scantool won't reset the computer, it will only clear the codes.
This is a problem with this mod and is why the deflector is there in the first place, it will stop the rush of air coming into the engine which screws up the MAP readings.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 11-26-2006, 09:57 AM   #78
agcneo
agcneo's Avatar
agcneo Normal reputation
so am i better off putting a new throttle plate back on? the computer seemed to relearn it, and it does have pickup, but my idle is a tad bit higher, and it still hesitates. but when it goes, it goes!
you may have a faster car.....but i can still drive over yours
agcneo is offline   Reply With Quote
Old 11-26-2006, 10:57 AM   #79
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
this mod should not cause the engine to hesitate and idle should not change unless you messed with the hole in the plate or the rivits.
Old 11-26-2006, 08:13 PM   #80
BlazerLT
AF -Advisor
BlazerLT's Avatar
It has been known to cause a hesitation seeing the deflector place is there to stop the initial air gush coming in which will screwup the map sensor reading.
Old 11-26-2006, 10:52 PM   #81
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
what map sensor are u talking about? the 96+ just uses MAF so readings would not be affected by the mod. i havent had any problems after performing the mod.
Old 11-27-2006, 12:16 PM   #82
agcneo
agcneo's Avatar
all i did was take that plate and grind it away. is it possible that there is turbulant airflow cause by this somehow, that that is causin the hesitaion?? i didnt touch any rivets, or the idle hole. maybe i should have mentionedim running a full K&n with spacer on it.does that help any
Old 11-27-2006, 08:55 PM   #83
BlazerLT
AF -Advisor
BlazerLT's Avatar
Remove the TBI Spacer, doesn't do a thing.
Old 11-27-2006, 09:25 PM   #84
blazes9395
Newbie mod
blazes9395's Avatar
blazes9395 Normal reputation
So what did you do with the riviet holes, is there something in place of them?
blazes9395 is offline   Reply With Quote
Old 11-27-2006, 10:33 PM   #85
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Just to clarify earlier posts in this thread... The OBDII equipped 4.3L engines use both a Mass Air Flow (MAF) sensor and a Manifold Absolute Pressure (MAP) sensor. Although MAP sensor readings will not be affected by performing this modification, MAF readings can and will be skewed.
old_master is offline   Reply With Quote
Old 11-29-2006, 06:51 AM   #86
agcneo
agcneo's Avatar
the rivets are still there, not moved, not touched, i just ground off the half moon peice. should i rip all that out and replace the rivets. sorry im makin this simple mod sound so friggen retarted and hard. and the spacer is off now.
Old 11-29-2006, 08:01 AM   #87
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yes, the MAP will be affected when you get the sudden intake without the plate in place.
That is why it is there.
You will get a change from both sensors which will cause the hesitation.
Old 11-29-2006, 03:41 PM   #88
TheBrettster
AF Premium User
TheBrettster Normal reputation
BlazerLT - I should remove my TB Spacer as well ? Even if i'm putting an after market intake on ?
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
TheBrettster is offline   Reply With Quote
Old 11-29-2006, 04:49 PM   #89
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yes, remove it.
TBI spacers do nothing and have in some cases been proven to actually reduce horsepower.
Old 11-29-2006, 08:43 PM   #90
TheBrettster
AF Premium User
There went 100 bucks.
Bookmarks
Google
Web AF
