Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 03-24-2006, 09:58 PM   #61
blazes9395
Newbie mod
blazes9395's Avatar
blazes9395 Normal reputation
Re: Throttle plate mod
I agree with the MAF screen being there to help straighten the air flow, I beleive that is one of the amjor reasons its there. While I don't have a MAF as I have a '93 and a '95 CPI engine, I do have a camaro that utilizes the MAF sensor. I pulled the screens on my camaro - I wish I hadn't. Connecting the cars computer to watch real time values shows the MAF sensor having inconsistent eratic values that the computer has to compensate for. I blame the erratic values because of no screens to smooth out the air passing by the sensor. The throttle body mod, I am interested to hear what people have to say about it. Your idle RPM should not change - the VCM controls idle trim, and it should idle where it has always idled before. As for a lean cylinder problem, not true. While this was true with carburated engines, and even throttle body injection, the same cannot be said for the CSFI and even the CPI for the matter. The throttle body injected models were known to have lean cylinders especially the farther cylinders, 1&2 and 5&6. The air/ fuel mixture charge was taken more easily by the two middle opposing cylinders in these engines, its was a shorter route for the air/fuel charge to travel. As for the CSFI engines, this was eliminated by the introduction of an injector for each cylinder. Each cylinder gets the same amount of fuel for combustion as determined by various readings the VCM monitors. The CPI system is somewhat the same, with each cylinder getting its own fuel nozzle. I cannot see a lean conditin to exsist with these newer fuel delivery systems. As for having better response and power, yes I can see that - your getting more air in the engine, more air flow means more power. I really cannot see what the restrictor is there for. The only reason I can think of is to help lower emissions, by restricting higher air flow volume.
blazes9395 is offline   Reply With Quote
Old 03-24-2006, 10:12 PM   #62
Cloud Strife
Cloud Strife Normal reputation
Your explanation about the lean cylinders is what I was suspecting, but I have very limited car knowledge so I really couldn't comment.
So if what you say is true, then a cold air intake would truely come in valuable if you did remove this restrictor plate.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Cloud Strife is offline   Reply With Quote
Old 03-24-2006, 10:43 PM   #63
blazes9395
Newbie mod
blazes9395's Avatar
A cold air intake will without a question help. The only drawback now is as fast as it comes in the engine, it still has to exit too. A good exhaust system with a good flowing muffler and mandrel bent tubing will make the intakes mods that much better.
Old 11-10-2006, 12:40 PM   #64
Marcinko
Marcinko Normal reputation
I will definately be doing this mod. Can anyone tell me if they have this mod done as well as the TPS mod? To refresh you memory it is the one where you drill the TPS and rotate to raise or lower the TPS voltage.
I am wondering what the performance is like with both mods done.
Thanks,
Marcinko
Marcinko is offline   Reply With Quote
Old 11-10-2006, 01:45 PM   #65
muzzy1maniac
muzzy1maniac's Avatar
muzzy1maniac Normal reputation
do you have a link to the TPS mod?
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
muzzy1maniac is offline   Reply With Quote
Old 11-10-2006, 01:58 PM   #66
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Don't start messing with that. TPS mods do nothing.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 11-10-2006, 02:07 PM   #67
muzzy1maniac
Not sure I would have even attempted it. I was curious though.
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 11-10-2006, 03:35 PM   #68
Marcinko
Do a quick search for TPS Mod and you find it.
BlazerLt - I have done neither to my truck, but was curious if someone had and if so, what the outcome was.
My thought was that it would be counter productive to both.
It does sound as if consensus is the TB mod is worth the time and effort.
I have been keeping track of my truck maintenance and fuel mileage with a program called Autowolf. So I have about 6 months of fuel mileage data. When I have done the mod and have substantial mileage history I'll post the results.
(Pre -new engine and Post -new engine) If your curious my mileage before was 18MPG and after the engine change fell to 15MPG.
If your interested in the program it can bee seen at http://www.lonewolf-software.com/automotivewolf.htm
Old 11-10-2006, 07:46 PM   #69
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
ZL1power69 Normal reputation
Send a message via AIM to ZL1power69
The plate mod is worth the time but on the 96+ V6 you can't do the TPS mod cause there is not enough material on the sensor to drill out. even if it could be done, it would work against the plate mod. I did do it on my 95 and it did work. also my Grandfather did it on his 95 Mazda b4000 and it worked. but anyway, could we try to keep this thread on topic though. feel free to start a thread about the TPS in the performance section.
2000 Chevy Blazer ZR2
Performance: AEM intake, TB mod, ported stock y-pipe w/precat deleted, 3in catco cat, 2.5in Flowmaster 40 DF,
March pulleys, MSD SF ignition, Taylor 8.2 wires, Transgo shift kit, Corvette servos, B&M trans cooler.
Suspension: Knaffle 1.5in lift shackles, 1.25in rear wheel spacers, 31in BFG AT's
Exterior: custom ZR2 decals, bug guard, vent visors
Interior: Lanzar headunit w/ ipod input, Pioneer speakers, Scanguage II
http://www.cardomain.com/ride/3013891
ZL1power69 is offline   Reply With Quote
Old 11-10-2006, 09:11 PM   #70
Marcinko
Sorry, my intention was not to get anyone off topic. Rather want to know personally if the TB mod (on topic) was a good idea to combine with the TPS mod (off topic).
Thanks for the input. I am sure now people who have done the TPS mod (off topic) will have some insite on whether to accomplish the TB mod (on topic) or not.
Knowledge is power!!...right??
Old 11-10-2006, 09:30 PM   #71
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
the TPS mod works on some applications but can not be performed on the 96+ engine, so only the throttle plate mod can be done, not both. The throttle plate mod is worth the effort.
Old 11-10-2006, 09:33 PM   #72
Marcinko
Thanks ZL1---that was the answer I was looking for. I appreciate everyone's combined knowledge on this forum.
Have a great weekend all!!
Old 11-21-2006, 05:42 PM   #73
TheBrettster
AF Premium User
TheBrettster Normal reputation
BEST MOD I'VE DONE. PERSONALLY.
I drive my truck a little hard and now the engine doesn't sound like is struggling at all. Engine never passes 3k rpms anymore.
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
TheBrettster is offline   Reply With Quote
Old 11-21-2006, 06:40 PM   #74
Cloud Strife
This is on my to do list next week when I replace all my gaskets on the engine.
Optima Redtop
Old 11-23-2006, 04:02 PM   #75
agcneo
agcneo's Avatar
agcneo Normal reputation
i did the mod, and it sounds simple. but honestly it seems like a loss of power, it hesitates now untill it hits higher rpms. did i do something wrong??! i have only put 50 miles on since i did it. do i have to wait for the long term memory in the ecu to reprogram itself?
you may have a faster car.....but i can still drive over yours
agcneo is offline   Reply With Quote
Bookmarks
Google
Web AF
