The alternator is mounted high and towards the back of the engine compartment. They are above the 30" mark that AM General specifies as the "water fording limit" for a stock diesel H1 (24" for the gassers made in 95-96).
The alternator is a standard GM unit, I recently got a replacement from NAPA for my rig.
During most fording deeper than 30", the truck may submerge to a level over the hood, but rarely is the truck in water long enough for the water to fill the engine compartment all the way to the top -- if it did, there would be some risk for shorting components out. Being a diesel, it does not rely on sparks to keep the engine running however, so you don't get the stalling effect that one gets from splashing a gas motor.
Hope that helps,
Originally Posted by lifelongslacker
First of all, I do not own an H1 (unfortunatly). But I would like to know how it is that your altenators do not short out when wet?! Are they sealed or just mounted in a really good spot?
Thanks.
