Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 03-09-2006, 12:49 PM   #16
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: 91 chevy lumina stall issue
The ECM's are a common problem on these cars due to being mounted under the hood and exposed to the elements. I have answered numerous other threads with the same symptoms. You can test the ECM 2 ways. Take the plastic cover off the inner fender on the pasenger side. When you gain access to the ECM, start the car and tap on it with a screwdriver handle. If tapping (lightly, don't go relieving your frustration on the poor little fella!!!) on the ECM causes the car to stumble and/or stall, the ECM is your problem. The other way is to check for injector pulse with a noid light. If you have good fuel pressure and spark, but lose injector pulse, the ECM is faulty.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 03-09-2006, 04:04 PM   #17
comptech_69
comptech_69 Normal reputation
Send a message via AIM to comptech_69 Send a message via Yahoo to comptech_69
how does your spark look? Check and see if all your coils are putting out spark
www.theimportkiller.com
comptech_69 is offline   Reply With Quote
Old 03-18-2006, 07:38 PM   #18
cheryllephillips@m
cheryllephillips@m Normal reputation
My 90 Lumina stalled out while driving it for firdt time after purchase. I put injector cleaner in tank and filled up took it out on highway and drove it for 2 hours during that time it sputtered like it had no gas pressing pedal got no response like it running out of gas? Checked fuel pump is running..have fuel pressure up to rail...started back up and git it home where it died in my driveway. Won't restart..tested coil packs and plug wires for spark got spark...tried disconnecting neg battery cable to "reset" sensorson recommendation of one mechanic nothing. If I spray starter fluid into breather it starts up and runs but as soon as I stop spraying it dies again. Any suggestions? Did I miss any(or just forgot to mention as it is soo basic)
troubleshooting?
cheryllephillips@m is offline   Reply With Quote
Bookmarks
Google
Web AF
