Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > How-to/Technical Info
How-to/Technical Info A wealth of information at your disposal.
Thread Tools Search this Thread
Old 05-14-2006, 12:01 AM   #16
C5Longhorn
C5Longhorn's Avatar
C5Longhorn Normal reputation
Re: How-to change the PITA #3 spark plug
Excellent tip. I used it today. It greatly shortened the time it took to change the plugs.
Thanks again.
Rick
Rick S.
'99 Chevy Blazer LS-Daily Driver - K&N Air Filter
'02 Mil. Yellow Z06-Vortex Rammer, FLP LT Headers, MTI LS1 Edit programming, Kirban Shifter, NGK TR-55 plugs and Taylor 409 wires, MOMO shift knob, Baer Eradispeeds, Ken King Interior accessories, APC headlights and PIAA 1100 Foglights, lowered, !CAGS
C5Longhorn is offline   Reply With Quote
Old 05-14-2006, 01:59 AM   #17
GirlBear
GirlBear's Avatar
GirlBear Normal reputation
Nice post! Although I found it easier to just remove the wheel and that flap (just tore it off). Then went straight in , also i popped out the rubber stopper in the plug socket. Don't worry i replaced the flaps.
http://jowulf.deviantart.com/
GirlBear is offline   Reply With Quote
Old 05-25-2006, 12:33 AM   #18
Hunter1
Hunter1 Normal reputation
Has anyone else thought to lift the engine up about an inch after that it is a shot above that steering rod.
Hunter1 is offline   Reply With Quote
Old 06-21-2006, 10:26 PM   #19
CreekBandDad
CreekBandDad Normal reputation
I have a '99 Blazer and this came in very helpful. I had to pull the air filter unit off first as that was above the steering shaft.
The other thing that is helpful is a spark plug boot puller. I used one my neighbor had and I am going to order one of my own. It was the OTC-7078. It is currently available on americanhomeoutlet.com for $4.95 each. Search for otc7078.
CreekBandDad is offline   Reply With Quote
Old 06-22-2006, 11:55 AM   #20
Brian_D
Brian_D Normal reputation
Thanks Rlith for the excellent tip! As a side note, I found a "pickle fork" makes a perfect pry bar for the steering shaft. Also, a few squirts of Dupont Silicone Spray applied to the rubber in the spark plug socket makes for easier socket removal AFTER installing new plugs.
Brian_D is offline   Reply With Quote
Old 07-22-2006, 02:13 PM   #21
midnight_lost
midnight_lost Normal reputation
I just used a breaker bar witch had enough clearence to loosen the plug until I could just finish removeing it by hand and to put the plugs back in I've always used a 6-8in piece of vacum hose to help fight cross threading.
midnight_lost is offline   Reply With Quote
Old 09-04-2006, 03:59 PM   #22
bmitchum1
bmitchum1 Normal reputation
Lightbulb Re: How-to change the PITA #3 spark plug
This is the most helpful peice of info. Thanks a bunch. I changed my plugs about 6 months ago and couldn't get to the # 3 spark plug Now with the help of you I can.
bmitchum1 is offline   Reply With Quote
Old 09-04-2006, 10:31 PM   #23
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Problem with that is that you stress the motor mounts
rlith is offline   Reply With Quote
Old 10-28-2006, 12:39 AM   #24
riptide44
riptide44 Normal reputation
well i'm new here ..... someone mentioned lifting the flap inside the wheel well to get at the #3 spark plug -- that is the way i've seen most gm techs do it and is also how i do it - i just use a 5/8 spark plug socket followed by a swivel ( or knuckle ) then a couple of 3 inch extentions on a 3/8 ratchet - its really crampped in there for big hands but it does work - and might as well do number 5 plug while you are there .
riptide44 is offline   Reply With Quote
Old 04-04-2007, 01:55 AM   #25
CustomDeluxe
CustomDeluxe Normal reputation
Thank you for this write up, after an hour of finageling and cursing I came in to do some research. After finding this thread, everything was back to normal in 20min. You are a life saver. kudos!
~RIP 1977 Chevy CustomDeluxe
CustomDeluxe is offline   Reply With Quote
Old 05-11-2007, 08:10 AM   #26
comp
comp Normal reputation
good thread
comp is offline   Reply With Quote
Old 06-12-2007, 10:14 PM   #27
frankiem
frankiem Normal reputation
The way i change the #3 plug is I use a snap on spark plug socket with a 18mm stubby wrench this allows you to get right in there behind the steering shaft and take the plug right out. sometimes it is also easier if you cut the rubber over the shaft. Then to put the plug in i use a little piece of 3/8'' rubber hose on the end of the spark plug to help me start the plug in the hole GOOD LUCK
frankiem is offline   Reply With Quote
Old 06-30-2007, 03:05 PM   #28
rayh059
rayh059 Normal reputation
I didn't have a problem using a wobble and an extension from the fenderwell. I believe I have a plastic cover over the area you show the bolt at, I'm not exactly sure. It was easier getting the plug out than it was getting the wire off
1994 Sonoma Extended Cab 4x4 Auto SLS
code "Z" Black ~130K Miles Stock
rayh059 is offline   Reply With Quote
Old 06-30-2007, 06:41 PM   #29
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
ZL1power69 Normal reputation
Send a message via AIM to ZL1power69
true. the second easiest way to get this plug is to put the plug socet over that plug and use a wrench from up top.
2000 Chevy Blazer ZR2
Performance: AEM intake, TB mod, ported stock y-pipe w/precat deleted, 3in catco cat, 2.5in Flowmaster 40 DF,
March pulleys, MSD SF ignition, Taylor 8.2 wires, Transgo shift kit, Corvette servos, B&M trans cooler.
Suspension: Knaffle 1.5in lift shackles, 1.25in rear wheel spacers, 31in BFG AT's
Exterior: custom ZR2 decals, bug guard, vent visors
Interior: Lanzar headunit w/ ipod input, Pioneer speakers, Scanguage II
http://www.cardomain.com/ride/3013891
ZL1power69 is offline   Reply With Quote
Old 08-06-2007, 09:37 PM   #30
Paul T
Paul T Normal reputation
Many Thanks to TOM B and RLITH and everyone. The link to RILTH was absolutely amazing advice. I may have given up on getting the Number 3 Plug out but the pictures along with the advice regarding the disconnection of the intermediate steering shaft from the steering box for access was right on the money and nothing short of pure brilliance!
So then, did the "tune-up" get rid of the misfire? Unfortunately the answer is no. But because at the very least I have 6 new plugs/wires, the misfire no longer stalls me and I could get to work.
Right now I still have two error codes. The P0300 (Random Misfire) and the specific P0305 (Number 5 Cylinder Misfire).
Have poured in to the fuel SEA FOAM and have driven the Blazer 120 miles without success. My biggest obstacle is being totally down and missing work which of course isn't good.
I don't know if I have the talent to pull-off an injector replacement in a short period of time. I know the injector is about $90-100.
Any idea on labor or how labor intensive this kind of a job is?
Thanks again to all. I know that at some point I will get to the bottom of it. Soon I hope.
Paul T
Paul T is offline   Reply With Quote
Bookmarks
Search this Thread:
Google
Web AF
