| Latest | 0 Rplys |
01-07-2006, 11:36 AM | #1 | |
93 TC Intermittent No Crank/Start
Hey guys, I'm new here trying to find a resolution for my grandfather. He has a pristine 93 Town Car with about 50k miles. It's an absolute creampuff always garaged and serviced by the local LM dealer. He's had an intermittent but recurring problem with no start. All electronics seem to be OK, battery charge is good, but no action from a turn of the key. He's been stranded several times with 3 tows to the dealer. Every single time, the dealer hops in and it starts. They can't find the problem. They've bench tested the starter and it's perfectly fine. I think they even swapped in a new one on the second visit. The problem is their inability to duplicate the problem. I've checked the archives and a couple other sites with little success. I'm thinking it's something to do with the anti-theft, but I'm not very familiar with Lincoln's system. My expertise is with older BMWs. Any and all help appreciated!
01-07-2006, 12:30 PM | #2 | |
Re: 93 TC Intermittent No Start
My uncle's 95' Town Car had a no-start problem just like what you mentioned, and it turned out to be the ignition control module going out. You might see if that dealership mechanic tested this module/ ignition coil.
You did mention the security system, however when this same type of system went out in my Buick, the problem completely disabled the car from starting at all until I had the steering column module replaced. I don't want to steer you in the wrong direction, since the symptoms may be different in a Lincoln, but I thought this might help. Good luck!
http://www.cardomain.com/ride/2653398 1992 Buick Park Avenue (Daily driver) 2001 Saturn SL1 (gas saver) |
01-07-2006, 03:01 PM | #3 | |
I forgot to clarify that it actually doesn't even crank. It's not an issue with spark or fuel. You turn the key and get a bunch of nothing. It doesn't even energize the solenoid.
01-08-2006, 09:40 AM | #4 | |
Hello Does gramps have an aftermarket kill switch on the car. The kill switch might be causing this problem. It also could have something to do with the neutral safety switch located inside the st column. This is hard to get to with out taking all the plastic houseing off the column, there is no way the dealership would want to check that thoroughly. Just something to think about. The next time it does that, tell him to play with the shifter. Pull it up hard in to the park position as far as it will go, or try to start it around the neutral position.
Thanks Mike |
01-09-2006, 08:20 PM | #5 | ||
Re: 93 TC Intermittent No Crank/Start
