| Latest | 0 Rplys |
12-07-2005, 11:09 AM | #1 | |
Need help!!!!!!! BLAZER NO START
I went to start my 97 blazer and it had no power. I figure battery dead. Go to jump and no luck at first. Finally after some time it goes. I let it run for a bit and go to drive it. When I put it in to reverce it stalled. No start, I tried to jump it agian and it wont start. The headlights come on now and the inside light too. The battery gauge is at 0 even when trying to start it. When the key is on the power option work but the idiot light in the dash dont come on when the key is turned over. Also it wont shift out of park. Is in a bad spot I go to get it moved fast. I live far away from were it is and my friend who has a tow truck said over $100 to get it near home. Not really what I want to do but. Any one now the problem
2006 Dodge Ram 1500 Quad Why Dodge it when you can RAM IT? 1964 Vw Baja 1600 |
12-07-2005, 11:11 AM | #2 | ||
Re: Need help!!!!!!! BLAZER NO START
From all the other reading I've been doing about the 97s my instinct would be the ignition module.
12-07-2005, 11:14 AM | #3 | |
I should add that it cranks over now but will not start.
12-07-2005, 11:16 AM | #4 | |
12-07-2005, 11:18 AM | #5 | |
YOu think this is the fix. Is there a way to check the ignition module before buying a new one
12-07-2005, 11:21 AM | #6 | ||
12-07-2005, 11:24 AM | #7 | |
Well I guess I will tow it home and do the swap. Thanks guys you are the best. Cant belive within seconds I have all this feed back THANKS so much. I let you know how things go. I not sure if I will be able to takle this fix but I will give it a try. Do you have pictures of the fix?
12-07-2005, 11:46 AM | #8 | ||
http://www.automotiveforums.com/vbul...CH+REPLACEMENT |
12-07-2005, 12:17 PM | #9 | |
Re: Re: Need help!!!!!!! BLAZER NO START
[quote=Gabe25]Sorry no pictures, but here is some instruction on how to do it. Its really not hard to do at all. Good Luck.
Thanks I ll print that out. The Switch is on its way and my buddy with the hook is towing it home soon. $100 tow $88 switch $8 Not big enough bottle of advil Ah to be a blazer owner NOT quite priceless............
12-09-2005, 02:11 PM | #10 | |
This post is awesome!!!!!!!! Just used it to do my switch. It made it easy. Thaks guys for giving me the heads up on it. Should be a sticky if its not already
12-09-2005, 02:19 PM | #11 | ||
12-09-2005, 02:25 PM | #12 | ||
Check ou this post http://www.automotiveforums.com/vbul...CH+REPLACEMENT Its awesome. So far the Balzer running great with the new switch. The post tells you all the tools you need. Its pretty easy.
12-09-2005, 03:51 PM | #13 | ||
AF -Advisor
Re: Re: Re: Need help!!!!!!! BLAZER NO START
1995 Factory Blazer Service Manual for sale, PM if interested. |
12-09-2005, 04:17 PM | #14 | ||
Problem?
12-09-2005, 05:15 PM | #15 | ||
Yea i see that now sorry. UM, j/w how much does the part cost, and am i replaceing that whole assembly where i stick my key in. If so will i have to carry around 2 keys one for igition and one more my doors? |
Thread Tools | |
