Go Back   Automotive Forums .com Car Chat > Isuzu > Amigo
Old 12-06-2005, 11:19 AM   #1
nodaclu
Bizarre Alarm Problem on '99 Amigo
Hi all,
I've searched and seen several posts where people have their alarms go off randomly, but I've haven't seen, or heard of anything quite like this before.
With stunning regularity (and usually about 2am in the morning - I'm *really* popular with my neighbors) my alarm will go off, and won't shut off until I go out and physically shut it off.
Now here's the weird part - the only time it does this is when the outside air temperature drops below freezing!!!
At no other time does the alarm ever malfunction. I temporarily solved the problem last winter by putting a small space heater in the garage. But I've moved since then, and can no longer put the Amigo in the garage.
I thought I had solved the problem by not setting the alarm at night, but lo and behold, it went off again at 2:20am this morning. This also happened to be the first night we dropped below freezing in 10 days - exactly the last time the alarm malfunctioned in the middle of the night.
If anyone can offer any thoughts on this, I'd really appreciate it. I've already checked the hood and tailgate pins, and can't find a problem there.
Thanks in advance,
~Mike
nodaclu is offline   Reply With Quote
Old 12-12-2005, 05:45 PM   #2
nodaclu
Re: Bizarre Alarm Problem on '99 Amigo
Anyone, anyone? Bueller, Bueller?
Old 12-14-2005, 08:25 PM   #3
Christine375
Angry Re: Re: Bizarre Alarm Problem on '99 Amigo
You mean the alarm going off by itself at 3 or 4 in the morning ?? any ideas for me ?? i have a 1999 isuzu amigo and the only thing i can think that might have caused this is I had a car started installed can anyone help ??
Christine375 is offline   Reply With Quote
Old 12-14-2005, 08:30 PM   #4
Christine375
[quote=nodaclu]Hi all,
Thanks in advance,
~Mike[/QUOT
I thought I was the only crazy one out there with this problem !!! only when it's cold out !!! I haven't read anything else on line either . I called isuzu they told me to call an alarm place who told me to call isuzu !!!
Old 12-30-2005, 06:26 PM   #5
brayburks
My 99 Amigo's alarm started going off randomly when it started to get cold. I read somewhere that it was the rear tailgate domelight switch. They said to just insert a washer behind the switch. It was a 5 min job. I added the washer and have had no false alarms since. Hope this helps.
brayburks is offline   Reply With Quote
Old 01-01-2006, 07:04 PM   #6
Christine375
Smile Re: Re: Re: Bizarre Alarm Problem on '99 Amigo
Hey Thanks !! At this points I will try anything !! Hopefully I will no longer have to deal with this !! thanks again
Old 01-01-2006, 07:04 PM   #7
Christine375
Old 11-05-2006, 05:16 PM   #8
JuanNYC
I thought I was the only one with this problem on a 1999 Amigo. My alarm does the same thing at night when the temperature gets to the freezing point.. doesnt happen in the summer time ONLY the winter. DO anyone know how to fix the problem with the alarm issue on a 1999 Isuzu amigo?? please help
JuanNYC is offline   Reply With Quote
Old 11-05-2006, 05:34 PM   #9
trooperbc
trooperbc's Avatar
did you see and try the tip about the washer and tailgate light switch in post #5 above in this thread?
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
trooperbc is offline   Reply With Quote
Old 07-20-2015, 03:34 PM   #10
Robwild
Me 99 amigo used to have this random alarm problem too up until it just fixed itself one day. Recently, however, now that the weather is 90F again, it's acting up again in broad daylight! I'd like to try this washer/dome light switch thing if someone could post a more detailed description of the process?
Robwild is offline   Reply With Quote
Old 12-26-2016, 08:43 AM   #11
mikealarm
My alarm used to go off by itself, my problem was the battery I had it checked and it was OK, but when batteries loose some voltage and the alarm does not get it's full 12 volts alarms can go crazy once I replaced the battery the alarm was fine.
mikealarm is offline   Reply With Quote
