Go Back   Automotive Forums .com Car Chat > Lincoln > Town Car
Thread Tools Search this Thread
Old 11-26-2005, 11:05 PM   #1
newway13
Turn off the "AIR SUSP" Message
I change the air suspension from my 1998 Lincoln Town car and need a help to find how to turn off the air suspension message.
Thanks for any help.
newway13 is offline   Reply With Quote
Old 12-04-2005, 06:16 PM   #2
rlwatkins
Re: Turn off the "AIR SUSP" Message
i found the eaiset way to turn off the message is to unplug the relay located under the hood in a fuse box the relay is marked on the inside if box lid this worked when i converted to coil springs also try cutting the green/Lt green wires located in the trunk behind the air suspension switch insulate as if live
rlwatkins is offline   Reply With Quote
Old 12-06-2005, 09:30 PM   #3
mittle
Re: Re: Turn off the
Is there anything else that is required, I pulled the relay (#4) & the fuses for the air suspension (12 & 17) & the "Air Suspension" message still is there.
mittle is offline   Reply With Quote
Old 01-25-2006, 10:43 PM   #4
DriverBill
DriverBill's Avatar
Re: Turn off the
Take a look for this plug: To turn the light off and disable the air suspension, you must unhook the air suspension module.
The module is located in the luggage compartment, behind the air suspension switch. Pull back the wall carpet and remove the 2 nuts that hold the suspension module. Unplug the suspension module and bolt the module back in place. (Do not remove module from vehicle. Leave in vehicle incase you want to put air suspension back on your vehicle.)
Did this help? By now, you may have resolved this. Sorry it's been so long since your original post. I just found this site and signed on Jan '06.
DriverBill
DriverBill is offline   Reply With Quote
Old 02-14-2013, 01:15 PM   #5
HaroldEP
I have confirmed with a Federal Mogul technical specialist that their instructions with the coil conversion kit are NOT correct for 1998 Lincoln Town Cars and later models. Because the air suspension system is now linked with the Electronic Variable Orifice Power Steering and data is sent from the Air Suspension/EVO Steering Module over the Multiplex Communication Network there is now NO WAY to shut off the air suspension warning message after converting from rear air springs to coil springs. He assured me that the coils work well after the conversion, but one has to be willing to live with the warning message. He also told me that they have requested the coil manufacturer (Moog) to correct their instruction sheet to reflect this reality on the newer models, but so far they have chosen to continue with the old instruction sheet.
HaroldEP is offline   Reply With Quote
Old 02-14-2013, 08:28 PM   #6
DriverBill
DriverBill's Avatar
Good work, HaroldEP, I have a '96 and the info I got worked for me. The newer model, 1998, apparently, made a change in how they deal with that.
Thanks,
Bill
DriverBill
'92 Lincoln Cartier (Rest In Peace),
'96 Lincoln Signature
'66 El Camino (Days Gone Bye)
'79 El Camino
Bookmarks
Search this Thread:
