| Latest | 0 Rplys |
11-19-2005, 07:03 PM | #1 | |
2002 Windstar Fuel Pressure Problem
My 2002 Windstar would not start on three separate ocassions. Initial troubleshooting showed that it is due to a lack of fuel pressure in the fuel rail. Further troubleshooting on the 3rd no-start event showed the following:
* The fuel pump and fuel pump relay fuses are OK * The fuel pump relay is OK * When the key is turned on the fuel pump relay engages momentarily but the pump never really gets going * When there is power to the fuel pump it runs normally and the car will start and run normally * When the key is turned on there is power (12+ volts) to the coil side of the fuel pump relay. Momentarily this circuit is grounded and there is momentary power to the fuel pump. After about 1 second with the key turned on, the fuel pump is not runnning and the engine won't start. With the key turned on, if a ground is provided to the coil relay circuit, the relay engages, power is provided to the fuel pump and the car starts and runs normally. The circuit diagram shows that the Powertrain Control Module provides a switched ground for the fuel pump relay coil circuit. This circuit provides a momentary ground when the key is turned on and then switches open, causing the fuel pump relay to switch off power to the fuel pump. Continuity check of the wire from the fuel pump relay to the PCM shows that the wire is OK. Chassis grounds have been inspected and cleaned -- testing after this action showed no improvement. My questions are: What input to the PCM causes it to open and close the switched ground for the fuel pump relay? What would the risk be if the fuel pump ran continuously when the key was on -- except for accidents where the pump is shut off by the inertia fuel shut off switch? Does this sound like a broken PCM? Any help would be greatly appreciated. |
11-19-2005, 08:32 PM | #2 | |
Re: 2002 Windstar Fuel Pressure Problem
The PCM may itself be losing power.
Investigate the condition of the PCM power relay; it may be failing. |
11-19-2005, 08:36 PM | #3 | ||
Re: Re: 2002 Windstar Fuel Pressure Problem
I should also note that there are no fault codes to help us figure out what the problem is. |
11-20-2005, 01:06 AM | #4 | ||
11-20-2005, 08:46 AM | #5 | ||
This morning I checked the pressure in the rail and it read zero. I left the pressure gauge on it and my wife turned the key to "on". I did not hear the pump start up and the gauge read zero the whole time. By the way it amazes me that other people who don't know me are taking the time to hear my problem and help me try to fix it. I really appreciate everyone's help. |
11-20-2005, 09:14 AM | #6 | |
For the $20 it would cost, I sure would like for you to replace the PCM power relay and the fuel pump relay ... with brand NEW ones.
And apply some lubricant to the relay bases. (Humor an old man.) |
11-20-2005, 10:23 AM | #7 | ||
11-20-2005, 10:43 AM | #8 | ||
11-20-2005, 12:49 PM | #9 | ||
11-20-2005, 04:48 PM | #10 | |
But it will start if you apply ground to the fuel pump relay ?
11-20-2005, 04:58 PM | #11 | |
Another question: Does the 2002 have a dual,or single, fuel line system?
The future is single-line systems (no return line to tank). My '99 has two-lines. Don't know if any Windstar model year went to single line. |
11-20-2005, 05:18 PM | #12 | ||
11-20-2005, 05:22 PM | #13 | ||
11-20-2005, 06:35 PM | #14 | |
I would guess that once the engine starts, the PCM is looking for a signal that proves the engine is continously running (CPK or the like) ... but I'm guessing. You would think this would cause a MIL (CEL).
Tomorrow, when my head clears of cognac, I'll try the shop manual for a clue. |
11-21-2005, 04:22 AM | #15 | |
OK. The PCM is supposed to give you a one second start-up period, after which it will maintain the fuel pump if a CKP (CranKshaft Position) sensor signal is received. (Per the Powertrain Control/Emissions Diagnosis Manual.)
Since your car is running OK otherwise, I believe that somehow your PCM is losing this CKP info internally. In other words, the CKP info is used to maintain ignition and fire the injectors ... but lost for the fuel pump drive. I believe it would be safe enough to just remove the fuel pump relay and insert a jumper to replace the relay contacts. Also, just for the heck of it ... you might look over the connector to the crankshaft sensor ... easier said than done, as its not easy to reach. And inspect the harness connection to the PCM. Use some of that lubricant here. Also, roll back the harness, from the PCM, and make sure the harness has not been damaged against the ac tubing or something else on the firewall. (Mine had.) |
