| Latest | 0 Rplys |
11-09-2005, 05:17 PM | #1 | |
PO122 code
I got a code PO122 throttle/pedal position sensor/switch A circuit low input.What does this mean and what do I need to fix it?Would this have any effect on gas mpg?
11-09-2005, 06:13 PM | #2 | |
AF - Advisor
Re: PO122 code
About what it says. circuit low output.
A 4.3 should read .47 volts a idle A 2.2 should read .2-.9 volts at idle. Check the voltage on a scanner or volt meter. If not in specs adj or replace tps sensor. Also clean tbi butterfly. MT |
11-09-2005, 06:33 PM | #3 | |
A990 racer
Re: PO122 code
Geez, MT2500, it's an x cab they only come with 4.3's, you couldn't see that?
11-09-2005, 06:44 PM | #4 | |
AF - Advisor
Re: PO122 code
Maxwedge
Well I Guse I should have looked at the picture. But That cow catcher throwed me off on the engine. MT |
11-10-2005, 01:26 AM | #5 | ||
Banned
Re: Re: PO122 code
I never knew that |
11-10-2005, 05:22 AM | #6 | |
Re: PO122 code
Thanks.Cowcatcher?It's not that big.
