Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > How-to/Technical Info
How-to/Technical Info A wealth of information at your disposal.
Thread Tools Search this Thread
Old 07-03-2006, 04:55 PM   #31
rental blazer
rental blazer Normal reputation
Re: Door pin and bushing repair How-To!
after replacing ....get litiuimn grease in a spray can and keep relubeing it every month or oil change or so to keep it lubed up.... thats what i do with mine..
rental blazer is offline   Reply With Quote
Old 07-06-2006, 12:13 PM   #32
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Good advice, lube is the key here. No sense changing them if you are not going to lube them a lo or they will be bad in no time.
Kinda like replacing your balljoints and such and never greasing them, there is no real point.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 07-11-2006, 06:30 PM   #33
y2kblazer
y2kblazer Normal reputation
unless you have the sealed ball joints with no zerk
y2kblazer is offline   Reply With Quote
Old 07-11-2006, 06:49 PM   #34
BlazerLT
AF -Advisor
BlazerLT's Avatar
Which is very rare on a Blazer.
Old 09-08-2006, 09:12 PM   #35
dss56
dss56 Normal reputation
can you just replace the top hinge bushings without taking the bottom hinge appart?
Looks like i just need the top hinge pin and bushings replaced.
thnaks
dss56 is offline   Reply With Quote
Old 09-08-2006, 10:15 PM   #36
DINO55
DINO55's Avatar
DINO55 Normal reputation
thnaks
NOPE, The bushings must be pressed in, You will end up dammaging the bottom bushing in the process, maybe even bending the bottom hinge.
Do both at the same time, Under an hour job. Make sure you use the GM DOOR SPRING REMOVAL TOOL, it will make the job a cake walk....
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
DINO55 is offline   Reply With Quote
Old 09-09-2006, 02:41 PM   #37
george_k
george_k Normal reputation
I clean and regrease mine with white lithium grease every 3000 - 5000 km so as to hopefully avoid (or at least prolong) having to replace them.
george_k is offline   Reply With Quote
Old 09-10-2006, 07:32 PM   #38
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Good rule of thumb
rlith is offline   Reply With Quote
Old 09-11-2006, 10:38 PM   #39
alblogg
alblogg's Avatar
alblogg Normal reputation
Originally Posted by rtreptow
My 1/4" ratchet extension is no doubt shot. The end is mushroomed from me hitting it with the hammer to try and knock the pin out. Maybe it's not a quality tool? I don't know what to say about the bushing getting cracked on the way in. I did clean the hole out for the bushing and sprayed it down with WD-40. I did not grease it. I did make the little tool with a nut and bolt to squeeze the bushing into place. That worked slick! And yes, the bushings were in the right hole. Don't know why it would have cracked pounding the pin through? The only thing I can think of is if the door wasn't propped up enough and the pin was going through at a little bit of an angle? Does that make sense? When I did the first door a few months back, all went smooth. Not this time.
We all make mistakes some big some small, I've cracked a few in my time trying to get the bushing in the hole you had to weld up and drill out and sometimes it just don't seem like the hole is round because that bushing just ain't going in there.
'07 G6 Wife's car
'00 Malibu stock, just a parts getter.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
alblogg is offline   Reply With Quote
Old 10-25-2007, 08:09 AM   #40
mixin
mixin Normal reputation
Link to cheap door spring tool
http://www.harborfreight.com/cpi/cta...emnumber=95344
also available at the retail locations
mixin is offline   Reply With Quote
Old 11-10-2007, 11:53 AM   #41
99Montana
99Montana Normal reputation
Well... I've got to do mine on my 97 Sonoma.
Left side drops very little so I probably won't have to weld but the right side is eggshaped.
Sounds stupid but...
What size drill do I use after I weld it?
And does NAPA have quality pins?
Thanks for the help and excellent post
08 GMC Sierra Ext Cab Z71 4x4 (wife's new ride!)
99 Chevy Silverado Ext Cab 4WD 5.3 Plow Truck
99 Pontiac Montana Ext 3.4 SOLD
97 GMC Sonoma Ext Cab 4WD 4.3
99Montana is offline   Reply With Quote
Old 11-10-2007, 03:53 PM   #42
DINO55
DINO55's Avatar
I would just Dab some weld on the egg shape part of the hole on the hinge, then use a round file on the new weld, Filing just to the point where the new brass bushing will go in about a quarter of the way, then compress it in the rest of the way with a homade compresser tool.
I bought my new pins and bushings from the dealer.
Good Luck and post us back......
Old 11-29-2007, 07:17 PM   #43
99Montana
SUCCESS!!!
What I thought were going to be egged holes on the right side turned out to be little left of the bushings!!! Pins popped right out. Left side took a bit more work to get the pins out as it wasn't nearly as bad. Doing the worst side first prepared us for the left side. (Dad-in-law helped as he had a welder if we needed it.)
Spring tool worked slick (ratcheting box wrenches on the Christmas list!)
Pressing in the bushings worked even slicker (is that a word?!!)
Not even close to what I thought was going to be a difficult job but following all the great info and pics given here, this job was VERY EASY!!
THANK YOU TO ALL!!
Old 11-29-2007, 07:42 PM   #44
DINO55
DINO55's Avatar
Welcome, You are now an honorary member of the......
"New Door Bushing and Door Pin Club"
Old 12-01-2007, 07:37 PM   #45
JediKnight2
JediKnight2 Normal reputation
Doing this little repair next week....
JediKnight2 is offline   Reply With Quote
Bookmarks
Search this Thread:
Google
Web AF
