| Latest | 0 Rplys |
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
10-20-2005, 02:35 AM | #1 | |
95 civic ex turbo...
can i safely run 7psi of boost on my stock ex motor? it has 240k miles
10-20-2005, 02:51 AM | #2 | |
AF - Advisor
Re: 95 civic ex turbo...
240k miles. depends on what the compression and leakdown has to say.
99 JRSC@9.5 psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
10-20-2005, 11:55 AM | #3 | |
ok can u tell me what it should say b-4 i get it tested then?
10-29-2005, 10:47 AM | #4 | |
well i think 7psi is too much but i put a turbo on my 93 civic ex with 200,000 on it and i now have 215,000 miles on it and have had no problem @ 5psi using a fmu 12:1 and the timing retarded 2 degrees. just be sure to run enough fuel and not to far advanced, and use RESTORE with every oil change.
10-29-2005, 02:07 PM | #5 | |
lbs is all relative to what size turbo your running.
but since you have such a high milage motor do a compression check. ideal compression is in the 180 range across the board. all cylinders should have numbers close together. the leak down test will check your valves. but you'll probably want to tear the head apart and replace all gaskets and seals, do some valve lashing or have them done by a machinist(better) and have it acid washed. |
10-29-2005, 03:53 PM | #6 | |
AF -Advisor
with that many miles you're probably going to need to do some work to get that thing to hold together!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
Thread Tools | |
