Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV
Old 10-17-2005, 07:17 PM   #1
matthevelli
matthevelli Normal reputation
fuel pump not priming
whats up guys..first time using this forums!! anyway.. i drive a 95 honda civic cx with a jdm b16a obd1..ive been having fuel problems...my pump doenst want to prime..doest work at all..now i tested my pump hooked up pos..and neg.. to it and it works..i changed out my main relay..and check all my fuses...i dont understand why im not getting power..anyone..let me know..thanks.
matthevelli is offline   Reply With Quote
Old 10-17-2005, 09:38 PM   #2
snowman2005
snowman2005's Avatar
snowman2005 0
Send a message via AIM to snowman2005
Re: fuel pump not priming
did u check if u got power to the fuel pump harness? and make sure ur relay and fuses are good. it might just be something that didnt get hooked up
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
snowman2005 is offline   Reply With Quote
Old 10-18-2005, 02:15 AM   #3
superbluecivicsi
AF - Advisor
superbluecivicsi Normal reputation
and dont forget to check the two grounds to the thermostat housing.
99 JRSC@9.5 psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
superbluecivicsi is offline   Reply With Quote
Old 10-18-2005, 09:25 AM   #4
matthevelli
yeah i have power to the harness when i use a jumper wire in my relay plug..term. 5 and 7..but when i put the relay in i dont have power..i have two bran new relays too..iduno ..fuses are good to..let me know..could it be a bad ecu?
Old 10-18-2005, 11:50 AM   #5
Crazyeight
Crazyeight Normal reputation
Check your ECU. Pull it and look for damage to the board - burned circuits. The ECU controls the ground for the fuel pump.
Crazyeight is offline   Reply With Quote
Old 10-19-2005, 04:25 PM   #6
snowman2005
snowman2005 0
sounds like a burnt fuse or ur just missing the harness that turns the relay on and off. ill see if i can find a wiring diagram
ive got manuals
Old 10-22-2005, 09:19 AM   #7
matthevelli
okay...thanks alot..
Old 11-11-2005, 09:33 PM   #8
tune up
tune up Normal reputation
Cool
the main relay dude of its just ur pump .
tune up is offline   Reply With Quote
Old 09-22-2009, 08:23 PM   #9
bacchus_gc
bacchus_gc Normal reputation
i have the same problem .... no ground on terminal #8 on the main relay... i bridge 5 and 7 and fuel pump start to work .... main relay is ok ... but pin 8 doesnt has ground //// any ideas??
bacchus_gc is offline   Reply With Quote
Bookmarks
Google
Web AF
