| Latest | 0 Rplys |
09-18-2005, 05:05 PM | #1 | |
Testing pick-up coil??
How do I test a pu coil on a 90 eldo 4.5. Have eratic miss on several cylinders. Anyone have specs??
Thanks Denny Update: Tested pu coil and shows 700 ohms. Had a Miss and one bank of fuel injetors were inoperative due to a blown fuse at the U/H relaly and fuse center. I now got a code e041 and went for a new Hall effect swithch/ cam sensor. Then I found a broken groung wire inside he dist. so now I can test the cam sensor again. I hope this caused my bad miss. Anyone had a similar experience. Denny Last edited by gmburd; 09-22-2005 at 01:01 AM. |
09-24-2005, 11:43 PM | #2 | |
update on 90 eldo 4.5 miss
Had a bank of injectors missfiring and found the fuse to be blown Cam sensor fixed and code now history.
Tested Injectors for ohm readings which I believe were to be 13 - 16 ohms. I had 3 of them that were below 5 ohms. Replaced the injectors with used ones and veh runs like dream. Now all I have to do is pass air care. The shop said I needed a valve job and a head gasket to solve my engine miss problem. Glad I didn't go that far into the repair. As I said, the compression test didn't convince me that the head gasket or valves were gone. Hope this info helps. Denny |
01-14-2006, 10:48 AM | #3 | |
AF - Advisor
Re: Testing pick-up coil??
Man, that's some great troubleshooting.
Thread Tools | |
