Go Back   Automotive Forums .com Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 09-17-2005, 02:25 AM   #1
L8R_H8R
Do "Octane Boosters" work?
You know those little bottles of octane boosters that you can pick up at walmart? do those do anything for your car? do they really raise octane levels. I know NOS has their own octane booster, its 4x's as much as reg kind. those any diffrent?
L8R_H8R is offline   Reply With Quote
Old 09-17-2005, 02:37 AM   #2
-Josh-
Automotive love doctor
-Josh-'s Avatar
Send a message via AIM to -Josh-
Re: Do "Octane Boosters" work?
I've heard different things from everyone, it all depends on the octane you start with IMO. You start with a low grade octane it wont help much, but if you start with a high grade you might see a little gain from it.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
-Josh- is offline   Reply With Quote
Old 09-17-2005, 01:37 PM   #3
CBFryman
Banned
CBFryman's Avatar
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
no, not really. that little bottle of NOS octane booster MAY raise it by 1 point for 5gal of gas. the only adettive that boosts octane that has stood the test of time is lead which ataches to the hydrocarbons on a molecular level...instead of just a mixture of chemicals.
CBFryman is offline   Reply With Quote
Old 09-17-2005, 02:01 PM   #4
L8R_H8R
so they'er not worth it huh
Old 09-17-2005, 07:17 PM   #5
drdisque
drdisque's Avatar
Send a message via AIM to drdisque
they do raise your octane, just not very much, its way more effective to just buy higher octane gasoline.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
drdisque is offline   Reply With Quote
Old 09-18-2005, 12:24 AM   #6
SiGNAL748
SiGNAL748's Avatar
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Commercial octane boosters are a scam.
For example, if one says it'll raise your octane by 7 points. This is what they mean:
87 Octane + 7 Point Octane Boost = 87.7 Octane.
NOT 94 Octane.
SiGNAL748 is offline   Reply With Quote
Old 09-18-2005, 07:42 PM   #7
500
Back in the early 70's Dirt Bike magazine did an octane booster dyno test and talked to a few oil company chemists. Some of the stuff did work. One thing that sticks in my mind from the info: If it's not in a metal can then it is just a scam. The volatiles and other stuff in the brew that makes it effective passes right through a plastic container.
500 is offline   Reply With Quote
Old 09-20-2005, 06:43 PM   #8
drdisque
drdisque's Avatar
of course, that was the 70's, plastics technology has changed a lot since then.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 09-20-2005, 07:04 PM   #9
Brad4321
Running on 93 octane I get predetonation in one of my cars. With a single bottle of octane boost, that stops.
Whether or not it works for its intended use, I don't know, but it stops predetonation, which is a good thing in my bool.
Brad4321 is offline   Reply With Quote
Old 11-02-2005, 12:40 AM   #10
nismowu
nismowu's Avatar
Re: Do
NOT 94 Octane.
oh trust me, even worse!!
read them again...
most of addtive says "up to 5 points", "up to 10 points", or "up to 20 points"
what does that mean?
it means it goes up anywhere from 0 to 20 points,
so u might get only 1 points after all....who knows?
87+0.1=87.1
wow....how sad~
From my experiences, add a bottle to a full tank.
u wouldn't feel any difference....
and it actually reduce the gas mileage for that tank of gas with booster.
what I mean is:
a reguler tank of gas: 36 mpg
tank of gas with oct boost: 30~32mpg
they do help clean up ur fuel injecters though,
so it's not bad to use it once a while.
anyway, I wouldn't recommand to use them on old cars,
cause the alcohol from the booster tend to destory or aging
fuel lines made of rubber, gaskets.....etc.
2000 Sentra GXE
0-60 in 7.57sec
yet 35~37 MPG
nismowu is offline   Reply With Quote
Old 11-04-2005, 09:11 AM   #11
Twizted_3KGT
Twizted_3KGT's Avatar
how exactly does it clean up your fuel injectors? ...
yes, they work @ raising your octane to a certain point. So if you add one bottle, your octance will raise, but if you add 3 more bottles it won't raise any further past it's max point.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - 12.616@106.74 - 1.756 60ft. - 8.06@83.59 (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Twizted_3KGT is offline   Reply With Quote
Old 11-27-2005, 01:36 PM   #12
beef_bourito
beef_bourito's Avatar
it might have cleaning agents that clear gunk out of your injectors.
beef_bourito is offline   Reply With Quote
Old 03-13-2006, 12:58 PM   #13
sportsb4life7
Send a message via AIM to sportsb4life7
im sorry but im kinda new and i dont know how to quote so
"buy higher octane gasoline" said earlier ... what exactly is that.. just like premium gasoline from a gas station ? or where and how much can you get it for and how much more does it help from normal gas. thanks alot i appreciate it .....
sportsb4life7 is offline   Reply With Quote
Old 03-13-2006, 01:49 PM   #14
beef_bourito
the octane rating is written on the pump, you generally have 87, 89, and 91, at least in canada. higher octane gasoline requires a higher temperature to ignite so you can run more boost or compression without detonating (when the fuel ignites before you want it to, it's bad for the engine, it's like taking a sledge hammer to the top of your cylender head). if you don't need higher octane don't use it, it'll be a waste of money. you only need it if your service manual specifically sais you do or if you've increased the compression or turbocharged or supercharged your vehicle.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 03-13-2006, 03:54 PM   #15
sportsb4life7
Originally Posted by beef_bourito
(when the fuel ignites before you want it to, it's bad for the engine, it's like taking a sledge hammer to the top of your cylender head). .
how does this happen ? (early fuel ignition)
