View Poll Results: WHAT OIL FILTER DO YOU USE???
AC DELCO
56 |
23.83% |
AMSOIL
9 |
3.83% |
BALDWIN
2 |
0.85% |
BOSCH
4 |
1.70% |
DEUTSCH
0 |
0% |
FRAM
64 |
27.23% |
MOBIL 1
18 |
7.66% |
MOTORCRAFT
2 |
0.85% |
NAPA
17 |
7.23% |
PUROLATOR
21 |
8.94% |
STP
1 |
0.43% |
WIX
23 |
9.79% |
PENZOIL
1 |
0.43% |
QUAKER STATE
3 |
1.28% |
OTHER
14 |
5.96% |
10-28-2006, 10:38 PM
#61
Re: what oil filter do you guys use??
Originally Posted by ELindy
On the review of the Purolator Pure One oil filter at this site http://minimopar.knizefamily.net/oilfilterstudy.html he was concerned of a possible flow restriction but the graph below shows the flow rate of the Pure One to be about the same as the Wix. I think that the Pure One is one of the better oil filters.
WHat is the brand of the ultraguard? Never heard of it. Is that filter less effective, by flowing more? Is it compatible with synthetic oils? Please reply.
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
10-29-2006, 10:50 AM
#62
Ultraguard and Duraguard are both AC Delco oil filters.
10-29-2006, 12:33 PM
#63
So is the ultraguard the one to get? Is that what is preferred?
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
10-29-2006, 08:33 PM
#64
I used to use Delco Ultragards, til Checker's/Schuck's/Kragen stopped carrying them. Sometimes the SKU would cause the cash register to ring them up at the Duragard price, maybe that's why they dumped the item. They are supposed to be super filters. Only way I can get them locally is to order a case of 12 from a Delco warehouse distributor at $12-plus each!
So I've gone to the K&N.
11-08-2006, 11:02 AM
#65
Originally Posted by stashu
I have a 07 Silverado V8 4.8---I went to get a oil filter and Advantage auto did not have them. I wanted a Purolator Pure One. They had to order one, part number L12222. They looked up a 06 vs 07 and they are NOT the same.
Anybody know why the oil filters are different from 06 to 07??.
The other filter for it is AC/Delco PF48 which they did not have either.
Thanks for any commets!!
Stash
07 is a complete redesign. unless you have the classic design 07 then it is the same as the 06. they may have changed the size of the oil filter in NBS 07. the 07 NBS have more horsepower than the classic 07.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs.
01-08-2007, 10:49 AM
#66
Race bike you can use the standard chevy filter, just tell them when you go into the parts store you have the gm 5.3 silverado 99. They will give you the bigger "normal" size filter. The smaller filters are for the newer trucks. I dont know why GM would put such a small filter on a truck... But your filter and the silverado filter are the same base plate and thread pattern, Just ones a little longer.
01-09-2007, 03:43 AM
#67
i used to work in an oil change shop. we used to poke holes in the oil filters to drain the oil outa the filters. fram is JUNK! same with puralator oil filters. fram does not filter properly and without any strength at all, you can put a hole in it. one guy i worked with actually ripped one in half by twisting it. and pualator. we used puralator and they don't seal right. we had people come back all the time becuase the filters did not seal right. it was some thing internal on them some actually blew up. never had a problem with wix and you can never go wrong with oem. also i forgot, penzoil is the same as fram.
95 Ford F250 ext cab long bed Powerstoke Diesel, stock. 92 Ford Mustang LX 5.0: Trick Flow R series intake manifold, Cold Air Intake, Throttle Body, Larger Egr Plate, Flowmasters, 3.73 Gears, Off road H-pipe.
01-09-2007, 07:33 PM
#68
Originally Posted by mr.23sgte
you can use the standard chevy filter, just tell them when you go into the parts store you have the chevy 5.3 silverado 99. They will give you the bigger "normal" size filter. The smaller filters are for the newer trucks. I dont know why GM would put such a small filter on a truck... But your filter and the silverado filter are the same base plate and thread pattern, Just ones a little longer.
wow, no wonder why the manufacturer went w/ a short/smaller filter;
the deeper, more capacity & more filter paper is ~2x more $$$
partsamerica.com online quoted here...
PF46 @ $4.18
PF59 @ $8.99
thanx for the confirmation though that it's out there!  now to see if my bro would like that filter installed next time the pc says to change it  opcorn:
01-09-2007, 08:04 PM
#69
AF - Advisor
PF46 @ $4.18
PF59 @ $8.99
Ouch
Check some of your parts places that have ac filters.
A lot of them will cut you a good price on ac filters.
MT
MT
03-04-2007, 09:00 PM
#70
Yeah, IIRC from when I used ACDelco filters, the PF59 should only be like $4
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
03-07-2007, 11:19 AM
#71
Amsoil without a doubt
03-07-2007, 10:43 PM
#72
Ac Delco
03-08-2007, 04:52 PM
#73
Pure One filter with Mobil 1 oil
1999 GMC Sierra 1500
03-08-2007, 07:36 PM
#74
Can't get any better than that...
'03 Pontiac Montana Luxury 3400 SFI
'99 chevrolet 1500 Z71 4x4 5.7 Vortec
'95 Grand Am GT 3100 SFI
'88 IROC 5.7 TPI ( 48,000 original miles )
"ALWAYS"......  full synthetic!!!
04-08-2007, 10:26 PM
#75
WIX, or napa or gm -forget the fram there just sub-standard
