Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 08-26-2005, 12:31 AM   #46
Nate355RS
Nate355RS's Avatar
Nate355RS Normal reputation
Re: getting engine out
public ignorance is how i win a lot of races, i get the jump, they hear the v8 and think it's hopless and just back down. or i rev and they get scared it's 5.7 instead of a 5.0. it happens a lot more than i thought it would
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Nate355RS is offline   Reply With Quote
Old 08-26-2005, 12:34 AM   #47
drvngstorm05
drvngstorm05's Avatar
drvngstorm05 Normal reputation
the old 305 i had would tear alot of people out of the hole... i did get a few that backed down because of that... but i also did get wooped by alot of people... once that engine got passed 4000 rpm it pretty much had nothin else...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
drvngstorm05 is offline   Reply With Quote
Old 08-26-2005, 04:43 AM   #48
supervisor1886
Banned
supervisor1886's Avatar
supervisor1886 Normal reputation
What about a nice turbo? That should fix it.
And how did you a get a t56 in it? I know they need custom crossmembers, but what else?
supervisor1886 is offline   Reply With Quote
Old 08-26-2005, 06:19 AM   #49
drvngstorm05
if you were to swap the t56 into your third gen, bout the only things you need is the crossmember, and speedometer mods so the speedo reads right... that is if you already had a manual... if u had an auto you are going to need pedals, slave cylinder, cut a hole for the shifter and a new shift plate...
Old 08-26-2005, 01:03 PM   #50
DVS LT1
DVS LT1's Avatar
DVS LT1 Normal reputation
There you go Luos - I knew it was someone in here. BTW drvngstorm05 I also saw them drop the entire front suspension & motor/tranny on HP TV. Speaking of HP TV, did anyone else catch it a few weeks ago when they took that LS-Gun to the track? Stage II heads (can't remember if it had a bigger cam or not), Baer brakes, N2O kit and a new 12-bolt rear (although they used the same shitty control arms, etc.)
This thing NA was running high 13's! I was like what the hell? Mind you they didn't show 60ft times and the track was hot (car was also on drag "radials"). I'm sure the car was making decent HP but high 13's, shit. On the juice the friggin thing dropped 2 full seconds off though.
Just goes to show you big HP doesn't necessarily tell the whole tale. The only guys I've ever seen super-brag about their HP - the ones who will pull their dyno sheet out of the car - will never race their cars. Its cause they've been embarrased already and are sick of or out of excuses as to why their 500 rwph monster got smoked by car with a lot less shit and half the money put into it.
And eh, that story was classic drvngstorm05 - buddy asking you if its a 6. I probably couldn't have laugher at him either... just utter disbelief.
1995 Z28 Camaro
355 cid LT1
THE CAST IRON KING SHALL NEVER DIE!
LONG LIVE THE KING
DVS LT1 is offline   Reply With Quote
Old 08-26-2005, 02:01 PM   #51
Nate355RS
Nate355RS's Avatar
i think the 13 sec run was on the stock tires and on the 11.1 sec run they used the bottle and changed tires to drop the 2 seconds. they were also complaining about the transmissioin being junk or something. pretty bad ass car either way
Bookmarks
Google
Web AF
