08-24-2005, 05:57 PM
#61
Re: How much oil do you add when you change your oil and filter?
I put 4.4L in because that's what comes in the big jug. And then I fill as needed.
So I guess that's 3.9 quarts. This always shows 3/4 on the dipstick...
08-24-2005, 07:38 PM
#62
AF -Advisor
Re: Re: Re: Re: How much oil do you add when you change your oil and filter?
Originally Posted by Bruski
I have a '95 "W" and just changed my oil yesterday. I have always put 4 quarts in. Have to check it to see if it needs a little more.
I'll save you the time.
4.5 quarts.
1995 Factory Blazer Service Manual for sale, PM if interested.
08-24-2005, 10:18 PM
#63
Originally Posted by BlazerBoyLT98
Sorry about that BlazerLT.
Sorry about that BlazerLT,next time blazerboy and i will include you.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will.  Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
08-25-2005, 12:18 AM
#64
Does everybody else here fill the oil filter with oil before screwing it on like I do?
Just wondering.
'89 S10 Blazer 4.3 V6 4X4 with LOTS of rust.
08-25-2005, 03:20 AM
#65
Just wondering.
yes, and if anyone says no, start, you are suppose to prime them
08-25-2005, 08:59 AM
#66
With the remote oil filter it is kind of hard to do that because it screws on sideways, I always make sure the gaskets are lubed with oil but I have yet to pour oil into the filter on my 98 with the remote oil filter. Am I doing something wrong?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
08-25-2005, 09:20 AM
#67
Just wondering.
Always!
The remote oil filter it is kind of hard to do that because it screws on sideways, I always make sure the gaskets are lubed with oil but I have yet to pour oil into the filter on my 98 with the remote oil filter. Am I doing something wrong?
It needn't full to the top - pour a bit in at a time and let it saturate the paper. I tend to get it to about half and then have no problem installing it.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
08-25-2005, 10:12 AM
#68
I will now do that. Thanks
K&N Air Filter
08-25-2005, 01:09 PM
#69
AF -Advisor
You really can't prime a side mounted oil filter.
All you will accomplish is making a mess.
09-21-2005, 08:12 PM
#70
I got a W vin number and put 5 qt in, the dip stick shows i put too much its above the line, but then again when i put 4.5 quart in it was below the line.
09-21-2005, 08:57 PM
#71
AF -Advisor
Yes, 4.5qts will have the level ready a little below the full mark which is perfectly right.
09-22-2005, 11:30 AM
#72
2000 overfill
5 quarts in my 2000 makes the diptick read overfull by a significant amount. I also notice valve train noise when dipstick reads overfull.
I now ask the shop to put in 4 of the quarts and leave the 5th in the vehicle for me.
09-23-2005, 12:49 PM
#73
AF -Advisor
Re: 2000 overfill
I suggest you add 5 quarts yourself.
Something is wrong with the shops meter on their oil dispenser.
09-24-2005, 01:19 AM
#74
I put in 4.3L. Ha! j/k I put in 4.314159265358979323846264 Qts. sorry, j/k again. No, but really I put in 4.75 Qts. Crankcase and filter. I noticed that when I first got my Blazer, it had a longer AC Delco filter. Like a 4wd filter. I've always used the smaller 2wd ones, for my 2wd Blazer. Is there a snificant difference? (In filtration and in oil capacity?)
By-the-way: Is there usually that much 'empty-space' in your year'o'blazer's engine compartment S10Blazerman?
Computers prefer 2WD. how do I know? because "2" is closer to "W" and "D" than "4"
Made you look, didn't I...
K&N won't honor my warranty because I have 1,000,007 miles on my Blazer
09-27-2005, 07:23 AM
#75
I just changed mine this weekend.
The monkey at the local Murrays said 5.5qts.
So I buy 6 and put in 4 to about 3/4 on the dipstick.
Thats with the engine at operating temps. Cause if I check it cold it will be lower.
And WTF is the dipstick for if it isnt to check the oil level???????????
I would like to know how you get every drop of oil out of the engine in order to put the exact amount of oil that the crankcase holds.
Just my 2 cents.
