08-22-2005, 01:06 AM
#31
IT'S GOOD TO BE THE KING!
Re: Re: Re: How much oil do you add when you change your oil and filter?
Originally Posted by BlazerLT
Ah, that is crankcase only which doesn't include the filter.
5.0 qts is right with filter.
It is for the whole system. This includes...the engine, oil lines, filter, and oil cooler.
Back to school for you!
Oil Change 101:
Quote from http://www.partsamerica.com/Maintena...andFilter.aspx
"Find oil filler, add amount of oil given in owners manual, 1 quart less if filter is not changed. Start engine and check for leaks at drain plug. Lower car. Check oil level; adjust if necessary."
Quote from http://www.carcentral.net/content/gu...nOilChange.php
"There are a few things to take into consideration in determining how much oil to add to the engine. Start by finding the oil capacity indicated in your car or truck's owners manual. Subtract the amount of oil you used if you filled the new oil filter before installing."
Like this post? Hate it?
<----- Click the  and tell me what you think.
08-22-2005, 01:15 AM
#32
FYI - Fresh filter change and oil change - 4.5 quarts for me. Doesn't burn or loose a drop in that time. *crosses fingers* After starting the engine and letting it sit for an hour, the 4.5 quart fill up comes up to 3/4 of the hash mark. When hot, after driving down the freeway and letting it sit for an hour, it rises slightly. Never had any issues.
08-22-2005, 03:36 AM
#33
I must be putting way too much oil in mine , it seems to be leaking out the valve cover . What dip stick ? Don't you just add it til you see it in the hole . HAHA . I knew a woman who did this and said this right after saying her car sounded funny and then cut off .
08-22-2005, 10:05 AM
#34
AF -Advisor
Re: Re: Re: Re: How much oil do you add when you change your oil and filter?
Oil Change 101:
Blazee,
I specifically says "CRANKCASE" in the picture you gave us. That only means the amount you put in the crankcase without the oil filter volume included.
Honestly, why are you arguing with me, I am not trying to be mean to you or rude.
I don't need some links telling me how to change my oil, I know what is right and I know how to change my oil. You don't go by generic general guides on the internet on how you change your oil.
In my manual it says 4.5qts "with filter" change for my 1995. It specifically says with filter.
Give your local GM mechanic a call and ask him.
But realistically, better a 1/2 quart low than overfilled.
1995 Factory Blazer Service Manual for sale, PM if interested.
08-22-2005, 10:06 AM
#35
AF -Advisor
Exactly....
That is what my 1995 take and reads as well.
08-22-2005, 01:56 PM
#36
Re: Re: Re: Re: Re: How much oil do you add when you change your oil and filter?
[quote=BlazerLT
Well, in 1996+ 4.3L , the capacity went from 4.5qts to 5.0qts. This is going by the Chilton's repair manual which breaks it down year to year. This was also verified by a fried who is a GM mechanic and looked it up for me.[/QUOTE]
1995 and earlier have stamped steel oil pans.
1996 and newer have cast aluminum oil pans.
There is a slight difference in capacity, and that is why there is a difference in GM's recommendation starting with 1996.
4.5 qts is still correct for 1995 & older.
08-22-2005, 03:59 PM
#37
Blazee,
The information I posted is correct. Anytime that a manufacturor lists a spec, it is for the system, unless all the componets of the system are broken down and their capaicties listed. The manufacturor can't assume that customers will be able to judge and estimate certain parts of the system. Why would the manual tell you to change the oil and filter, then only give you the amount to refill part of the system? I only posted the links so you could see a few places backing up what I said, because you always want proof when someone disagrees with you.
My Haynes manual also says 4.5qts "with filter" and it is for 95-01.
08-22-2005, 05:03 PM
#38
AF -Advisor
Re: Re: Re: Re: Re: Re: How much oil do you add when you change your oil and filter?
It's your truck, do what you want, I am just trying to help people out and inform them.
Call you local gm dealer and ask them or better yet, call your local Jiffy Lube, they will have the amount on file for your year.
08-22-2005, 10:53 PM
#39
i put 5 quarts in my 95 and it burned a little oil and the oil level was well above the full mark. drained out the extra and now no oil. it was too high. i only put in 4.5 quarts and puts me right at the full mark. unless your going off roading as long as your in the upper cross hatches i think it will be fine. i do get a little worried when it gets to the lower crosshatchs.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series split rear, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers. Mag 500's with black center caps, C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
08-24-2005, 10:46 AM
#40
Re: Re: Re: Re: Re: Re: Re: How much oil do you add when you change your oil and filter?
This 4.5 qts applys too for blazer 93 s10, 4.3
08-24-2005, 11:06 AM
#41
AF -Advisor
Re: Re: Re: Re: Re: Re: Re: Re: How much oil do you add when you change your oil and filter?
Only if it is a CPI 4.3L.
If it is a TBI 4.3, you will need 5.0 qts total.
08-24-2005, 11:43 AM
#42
The oil war isn't in Iraq it is right here in the AF! I buy the 5 quart jug of mobil 1 fpr my 98 and I put it all in, I read just about to the top of my cross hatches on the dipstick and I don't worry about it until it gets below the cross hatches which it has only done once. Other then that it is drain, swap filter, fill with mobil 1! Set it and forget it! Good luck everyone!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
08-24-2005, 12:16 PM
#43
AF -Advisor
No war here.
08-24-2005, 12:29 PM
#44
Sure about that?It seems like it from what im reading LOL
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will.  Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
08-24-2005, 12:30 PM
#45
No war here.
Once again I was just making a pun. I actually find it to be quite comical  The best thing about this website other then helping a friend in need is the different views and methods on how to do things. Opens up a lot of new possibilities.
K&N Air Filter
