07-18-2005, 01:35 PM
#31
AF -Advisor
Re: blazer acceleration
A lot of those things can't be really seen as anything but routine maintanence.
The cat was probably ruined by the leaking CPI injector and nut kit and the new one will soon be ruined if you don't get it fixed.
1995 Factory Blazer Service Manual for sale, PM if interested.
07-18-2005, 04:42 PM
#32
bought the part today, its too hot to be outside and i didnt slept again last night so ill try to tackle it later tonight or tommorow
07-18-2005, 06:15 PM
#33
AF -Advisor
Did you buy the nut kit as well as the new upper plenum gasket.
07-18-2005, 06:28 PM
#34
well ive already had the plenum off once and replaced the seal then, i dotn know if it is reasuble because ive done that once on a neon and it sealed again fine, but i did pick up the nut kit, i might as well just buy a new plenum gasket because 12 dollars will save me aggravation, how much did you pay for your cpi i picked mine up new for 240 which is a fairly good price
07-18-2005, 08:07 PM
#35
AF -Advisor
Smart thinking, you want everything new so you know that everything is sealed tight.
Also, remember to clean the EGR port in the upper portion of the plenum that you remove.
07-18-2005, 08:38 PM
#36
response
yea egr valve has already been cleaned, before it was looked exactly like the one in your pic
07-18-2005, 09:25 PM
#37
AF -Advisor
Excellent, that will help.
Are you doing the work yourself?
If so, make sure you have some torx bits for the nut kit brace at the rear of the plenum.
07-18-2005, 09:31 PM
#38
yes im doin the work myself this is an easy job just a pricey part, i am most likely going to do it tommorow night, the truck is at aamco right now being looked at by another friend of mine becaus ehe has access to the computer scan tools, i dont know when the oxygen sensor comes up if it needs an oxygen sensor or if this is the cpi causing it, i bought anew one for him to replace it anyway, so when it comes back tommorow i am gunna tackle the job
07-18-2005, 10:45 PM
#39
AF -Advisor
Re: Re: blazer acceleration
Just be VERY careful when removing the poppets from where they enter the lower plenum. They are VERY brittle.
Also stuff shop towels down the 6 air tubes so nothing travels down into them by mistake.
07-19-2005, 05:05 PM
#40
response
ok just went up to aamco and talked to my buddy paul who owns the place, he said he looked at my truck himself and computer scanned it and says my problem seems to lie in the throttle position sensor, he said the sensor has gone bad and now the truck is not getting the fuel it needs when it needs it causing it to nto accelerate or even shut off, what do you think about what he had to say blazerlt?
07-25-2005, 12:01 AM
#41
AF -Advisor
Re: response
It could be defective as well, but still you have a leaking CPI unit and nut kit.
It still has to be fixed.
07-25-2005, 12:03 AM
#42
blazerlt i replaced the cpi and nut kit, no difference have any other ideas?
07-25-2005, 12:13 AM
#43
forgot to add tp and 02 sensor just replaced, computer still reads knock sensor, could this one sensore be causing all my problems?
07-25-2005, 05:20 PM
#44
AF -Advisor
So you replaced the TPS?
And don't worry about the cpi and nut kit, it had to be replaced.
07-25-2005, 05:41 PM
#45
yea tps was replaced i am 100 percent fresh out of ideas except that knock sensor code
