Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > Citroen > Xantia
Thread Tools Search this Thread
Old 07-14-2005, 03:58 PM   #1
peter_dunkley
Xantia electric front windows
Hello,
I have a 1997 1.9TD SX Xantia. Both front windows stopped working today. None of the three switches (one for the drivers window and two for the passenger window) appear to have any effect. The rear windows do work.
I have checked both the fuses (F29 for the windows and F30 for the switches) they are both fine. Both of the fuse connectors have power supplied to them.
The window switches do not appear to have any power supplied to them, applying power directly to a switch allows me to operate a window. I cannot hear a relay click when I activate the switch (either with or without power).
Has anybody seen this before?
I suspect the relay but I cannot check this because my Haynes manual does not identify the individual relays. I would still be a little confused if it was the relay because the Haynes circuit diagram indicates that the same relay is used for all four windows (and the rear windows do work).
Thanks,
Peter
peter_dunkley is offline   Reply With Quote
Old 07-21-2006, 11:23 AM   #2
tottsy
Re: Xantia electric front windows
Originally Posted by peter_dunkley
Hello,
Thanks,
Peter
Hi Peter
Have you managed to sort your problem. Interested as i have a Xantia 1.9TD 1997 and none of the windows are working. Have replaced the control unit and fuses but not sure about the relays how many there should be and where they are?
Thanks a lot
Sharon
tottsy is offline   Reply With Quote
Old 08-05-2006, 01:43 PM   #3
flissfloss
Hello Peter,I am having exactly the same problem with my xantia.If you managed to resolve it,then i would appreciate any help that you can give.regards steve
flissfloss is offline   Reply With Quote
Old 11-16-2010, 02:29 PM   #4
betuaintgotthis
I suspect your fault is in the wiring loom between the door and body. The constant opening and closing can weaken the wires untill they break. It is fiddely but you can simply just rejoin the wires.
betuaintgotthis is offline   Reply With Quote
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
