Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 06-20-2005, 03:10 PM   #16
wick111
wick111 Normal reputation
Re: Re: Re: Re: '01 Silverado fuel pump
Originally Posted by jeep_cj4x4
There is a sticker with a code on top of the fuel pump that the autoparts store will be able to tell which one you need.
yea I figured that's where the stcker is but I'd like to order the part before I remove the bed and then do the whole job in one day.
THX,
Eric
wick111 is offline   Reply With Quote
Old 06-20-2005, 03:35 PM   #17
wick111
I was afraid of that..... I wanted to get the pump before taking the bed off so I could get it all done in one day in case the pump is special order. Maybe the dealer can tell by the VIN number.... I'll give them a call.
THX,
Eric
Old 06-20-2005, 04:01 PM   #18
twomorestrokes
twomorestrokes's Avatar
twomorestrokes Normal reputation
Re: Re: Re: Re: Re: '01 Silverado fuel pump
THX,
Eric
Dealer should be able to tell from the VIN.
twomorestrokes is offline   Reply With Quote
Old 06-20-2005, 04:42 PM   #19
jeep_cj4x4
jeep_cj4x4's Avatar
jeep_cj4x4 Normal reputation
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
I think it's easier to remove the bed. Removing the tank, you need to be able to support it while trying to unhook everything, get it up and down without droping it (dont forget that any gas remaining in it will be sloshing back and forth making it hard to balance, and your working on your back upside-down.
Once you get the 8 bolts that hold the bed on removed, unplug the wiring harness at the back for the lights and take 4-5 screws out for your gas filler neck; just pick it up and set it on the bumper and top of the tire (or take it off and set it in the yard). That will give your plenty of room to get to the lines and pump while standing up and nothing has the possibility to fall or spill on you.
Removing the bed, you can do by yourself in about 3 hours or less (with the right equipment). Droping the tank I definetly recommend having a buddy or three to help.
Just my thoughts but I havent droped the tank....so... Maybe someone needs to do it and compare.
2001 Silverado 1500 5.3L 2wd, AMSOIL fluids w/ filter bypass kit
AMSOIL air filter, AirAid intake, Hypertech Programer
B&M shift kit, Flowmaster 50's, Linex bed
jeep_cj4x4 is offline   Reply With Quote
Old 06-20-2005, 04:52 PM   #20
kenwood guy
kenwood guy's Avatar
kenwood guy Normal reputation
Send a message via Yahoo to kenwood guy
ive done it in my 91 caprice it was hard but not to the point where I needed help the tank was less then 1/4 full( I belive 5gallons) I guess that helped
Thats My truck!!!!!.... 01 Silverado 4.3....A.K.A "The Urban Truck" .... In progress of making my own subbox-----now done!!
Mods:
-Blue instrument cluster
-Yellow drl's
- 03+ Tail light upgrade
- Blue plasma glow reverse lights
- Center console swap
kenwood guy is offline   Reply With Quote
Old 06-20-2005, 05:02 PM   #21
jeep_cj4x4
jeep_cj4x4's Avatar
I've done it with my jeep also but that tank is half the size of the one in the truck. It was as close to empty as I could siphon out and still heavy as He11 and awkward.
Old 06-21-2005, 08:53 PM   #22
99redsilverado
99redsilverado's Avatar
99redsilverado Normal reputation
i have done it both ways.......PULL THE BED, it is so much easier than dropping the tank, and you have access to your frame, if it is like mine was, then you can clean it all real easy, or go as far as i did and sand it down and paint it over.....my 2 cents
'99 Silverado 4 x 4
bunch of goodies
99redsilverado is offline   Reply With Quote
Old 06-21-2005, 11:20 PM   #23
Arsenik111
Arsenik111 Normal reputation
quick question, if my hard starting is due to the fuel pump am i also losing performance
Arsenik111 is offline   Reply With Quote
Old 06-22-2005, 11:46 AM   #24
99redsilverado
you could just depends on if the fuel pump is just having a hard time pressurizing or if it cant keep up with the motor
'99 Silverado 4 x 4
bunch of goodies
Old 06-22-2005, 03:18 PM   #25
twomorestrokes
Not necessarilly. If the check valve is bad, it will allow the system to lose pressure when shut off, causing hard start/ long cranking time while it fills the lines back up. The pump pressure output may be normal once it's running.
Bookmarks
Google
Web AF
