Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 05-24-2005, 05:03 PM   #16
profox02
profox02's Avatar
profox02 Normal reputation
Send a message via Yahoo to profox02
Re: oil filter adapter problem
i did the oil change about a week before the trip...and i did notice the oil filter had some oil on it the day before i left...
profox02 is offline   Reply With Quote
Old 05-24-2005, 06:15 PM   #17
mbumgua
mbumgua's Avatar
mbumgua Normal reputation
How high is your normal oil pressure; and how tight do you usually tighten the oil filter--did you tighten it more when you noticed the oil on it?
mbumgua is offline   Reply With Quote
Old 05-24-2005, 07:35 PM   #18
profox02
profox02's Avatar
Dont Know What The "normal" Oil Pressure Is ..it Goes All The Way To The End Of The Gauge....and I Hand Tight The Filter(1/2 To 3/4 Of A Turn After The Rubber Gasket Touches)...and Yes I Did Tighten The Filter When I Saw Oil...
Old 05-25-2005, 10:23 AM   #19
mbumgua
mbumgua's Avatar
I think perhaps the problem is your oil pump relief valve sticking and overpressuring the system. Normal oil pressure for a new chevy 350 is between 30-45 lbs or halfway to 3/4 on the gauge. I would hook up a temp press gauge with numbers and see how high it is. If relief valve is sticking you could use lighter oil or add a quart of dexxron in place of one quart of oil to free it up- or pull pan and check the pump.
Old 05-25-2005, 10:24 AM   #20
profox02
profox02's Avatar
got a new adaptor with oil cooler lines...this one seems to be alot stronger...put it one last night and it seems to run fine...but this morning it seems to have dripped a little oil..but i dont know if its from the adaptor or if its from all the oil that sprayed all over the place when the old adaptor broke....how tight should this one be(oil filter adaptor with oil cooler)?
Old 05-25-2005, 10:28 AM   #21
mbumgua
mbumgua's Avatar
Chevy book says same as other adapter-6.7 foot-lbs.
Old 05-25-2005, 10:31 AM   #22
profox02
profox02's Avatar
the torque wrence that im using starts at 15 foot-pounds...so i just went by hand it seems to be holding well
Old 05-26-2005, 10:33 AM   #23
profox02
profox02's Avatar
another ?....which way is the oil flow..does it go into the middle of the filter then out the little holes around the center???....im gonna add the oil cooler sometime not to long from now..the new adaptor seems to be holding well, no oil drips last night...
Old 05-26-2005, 12:47 PM   #24
mbumgua
mbumgua's Avatar
In the little holes out the big hole
Old 05-26-2005, 12:52 PM   #25
profox02
profox02's Avatar
Thanks For All The Help Mbumgua.
Bookmarks
Google
Web AF
