Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 05-04-2005, 12:52 PM   #16
corbinwaterski
corbinwaterski's Avatar
corbinwaterski Normal reputation
Re: 15000 mile oil?
http://www.mobiloil.com/USA-English/.../Homepage.aspx
and
http://theoildrop.server101.com/cgi/ultimatebb.cgi?
WAR UTAH!!
corbinwaterski is offline   Reply With Quote
Old 05-04-2005, 01:15 PM   #17
ZR800
ZR800's Avatar
ZR800 Normal reputation
Send a message via AIM to ZR800
Re: 15000 mile oil?
Know the Facts
AMSOIL Saves You Money!
AMSOIL extended drain intervals mean fewer oil changes, long term savings and convenience
Example:
Conventional motor oil companies recommend 3,000-mile drain intervals
Conventional 10W-30 Motor Oil
*(40 quarts needed for 25,000 miles) @ $1.50/qt. x 40 = $60.00
8 Standard Oil Filters @ $5.00 per filter x 8 = $40.00
TOTAL $100.00
AMSOIL recommends 25,000-mile/1-year drain intervals
AMSOIL 10W-30 Synthetic Motor Oil
*(6 quarts needed for 25,000 miles) @ $6.15/qt. x 6 = $36.90
2 AMSOIL Super Duty Oil Filters @ $10.00 per filter x 2 = $20.00
TOTAL $56.90
* Comparison based on 25,000 miles driven per year and 5-quart oil capacity, with one quart top-off for for filter change.
You save $43.10 per year using AMSOIL premium quality synthetic motor oil and oil filters. And at Preferred Customer prices, you save even more.
Even if you drive only 12,000 miles per year, the cost for AMSOIL is the same as you pay for petroleum oil now! But you still get better protection, lower engine temperatures, easier cold-weather starts and less engine wear. All of these benefits add up to an engine that will last longer and need fewer repairs. Change your oil and filter today and in six months change the filter again. That's it! What could be more convenient and good for your vehicle, too?
ZR800 is offline   Reply With Quote
Old 05-04-2005, 02:34 PM   #18
twomorestrokes
twomorestrokes's Avatar
twomorestrokes Normal reputation
Re: Re: 15000 mile oil?
Originally Posted by ZR800
Know the Facts
Amsoil IS a great oil. That's all i used for injector oil back when I rode 2 stroke sleds. However, I would never go 25k with the same oil in my vehicle. Deposits are deposits, whether it remains slippery or not.
twomorestrokes is offline   Reply With Quote
Old 05-04-2005, 02:52 PM   #19
ZR800
ZR800's Avatar
Snowmobiling also turned me onto AMSOIL. I have had amazing results. 2 stroke motor oil normally gums up what they call power valves on snowmobiles. I have only had to clean mine once in 8000 miles. Most clean theirs once or twice a year, averaging 1500 miles per cleaning. Most would also consider 8000 miles on a snowmobile very high miles and a tired motor. There was a recall on my motor due to rod clips which required a top end rebuild 2 winters ago at approximately 4800 miles, and the mechanics were amazed at the condition of my cylinders, pistons, and rings. In addition, my sled stock will still run even out of the hole and top end with brand new sleds of the same size 800cc motor. I swear by AMSOIL.
Old 05-04-2005, 03:06 PM   #20
BlenderWizard
BlenderWizard's Avatar
BlenderWizard Normal reputation
Send a message via AIM to BlenderWizard
Re: 15000 mile oil?
Where can one buy Amsoil?
BlenderWizard is offline   Reply With Quote
Old 05-04-2005, 03:25 PM   #21
ZR800
ZR800's Avatar
Re: 15000 mile oil?
WWW.AMSOIL.COM
Old 05-04-2005, 03:41 PM   #22
BlenderWizard
Re: 15000 mile oil?
Ok, I've read like 10 threads on theoildrop.com, and those guys REALLY talk in circles. Nobody ever makes a clear stand on anything. So, let me ask you guys: I am expecting my shipment of Royal Purple in a few days, but what oil should I use and how often should I change it if i want to get the longest life out of my engine? I drive normally, I do not go to the track, etc, etc.
Old 05-04-2005, 05:46 PM   #23
jethro_3
jethro_3's Avatar
jethro_3 Normal reputation
Re: 15000 mile oil?
THe trick with Amsoil or any other synthetic is to have a sample of the oil in your vehicle sent to a lab to check for contaminents, viscocity break down, and other peramiters. My co-worker is an Amsoil rep and he has 30K on the last change in a dodge diesel that is a farm truck. The last sample showed no problems and good for another 4K.
The idea is not to go forever, the idea is to use the oil until it shows breakdown and contaminents.
jethro_3 is offline   Reply With Quote
Old 05-04-2005, 05:54 PM   #24
Chevyman15004X4
Chevyman15004X4's Avatar
Chevyman15004X4 Normal reputation
Re: 15000 mile oil?
Im going to start never changing my oil. I will change the oil fliter out every 4-6 thousand miles and add whatever needs added and thats it. I know one person with a ford tuck that has 260 grand and ever since he owned it he has just changed the filter and added oil. I have seen and heard many people do this. Although I would use synthetic since I have read in many places petrolium based oils burn off and create carbon deposits and sludge real bad yet synthetic has very little burn off.
I want to expirement with this and see just how bad every one else is brain washed with the 3000 mile oil change. Besides, Nobody ever learned anything new by following everyone elses old ways. I feel as long as you change the oil filter, you are removing most of the dirt and metel deposits in the oil anyway. I have only 118k miles on mine but I have gone so far 12000 miles without changeing oil.
On the weight issue, I pick up 10w-40 most of the time just to be different. I live right above texas in the panhandle of oklahoma (Guymon) where it gets over 100 degrees with little to no humidity in the summer and sometimes below 0 degrees in the winter and I have not had any noise with my chevy truck with a 350, 84 ford van with a 302, suzuki sidekick with a 4 banger. ( I do change it in my lawnmower though since it has no oil filter)
Chevyman15004X4 is offline   Reply With Quote
Old 05-04-2005, 08:53 PM   #25
BlenderWizard
Did you see me mention my dad's '84 Silverado 305 with ~700,000 miles on it? This is exactly what he did. He had a small oil leak, and every couple of weeks, he'd add a quart. He's got a '81 with a 305 and a slight oil leak, and it is fast on it'sway to doing the same thing. it currently has ~250,000 miles on it. He only changes his oil filter when the rubber seal on them goes so bad, it begins to leak around it. The first SBC's didn't even have an oil filter.
Old 05-04-2005, 09:58 PM   #26
broughy84
broughy84's Avatar
broughy84 Normal reputation
Re: 15000 mile oil?
here is why I change my oil every 5k
Lets say you have a very small intake leak or head gasket leak. If The oil doesn't get contaminated enough in 5k to notice then it doesn't hurt anything and you drain it and change it. If you go 20k, you have 4 times as much coolant in the oil. I don't know if you all follow what I am saying, but I do, I guess!
Matthew Brough
1998 Chevrolet Venture -- 104,000 miles
1988 Chevrolet Silverado -- 156,000 miles
1996 Chevrolet Cheyenne -- 107,000 miles
My 96 and 88 before the resto.
My 88 after the Restoration.
broughy84 is offline   Reply With Quote
Old 05-05-2005, 08:55 AM   #27
twomorestrokes
Lots of luch Chevyman! I'll leave the testing up to you. Keep us posted.
Old 05-05-2005, 09:17 AM   #28
jeep_cj4x4
jeep_cj4x4's Avatar
jeep_cj4x4 Normal reputation
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
Re: 15000 mile oil?
everyone else has said something so I guess I will too. I have an '01 silverado. I switched to syntec at 60k. I now have 87k and have just recently started noticing piston slap. (never knew what piston slap sounded like until now). I change my oil about 4k mile intervals.
Also, I know on my '01 and I'm sure some other years, the oil senser thing is set up to illuminate the message center "change oil" light when it registers a breakdown in the oil, excessive contaminates or 10k miles. Which ever comes first.
2001 Silverado 1500 5.3L 2wd, AMSOIL fluids w/ filter bypass kit
AMSOIL air filter, AirAid intake, Hypertech Programer
B&M shift kit, Flowmaster 50's, Linex bed
jeep_cj4x4 is offline   Reply With Quote
Old 05-05-2005, 09:32 AM   #29
jethro_3
jethro_3's Avatar
Re: 15000 mile oil?
Talking with the tech at the Dealer, the Change Oil" light is produced by a formula according to how you drive. A sensor can not do the testing to check viscocity or other testing. When your light comes on take a sample and send it off to see what the oil really looks like. I bet you will not see a viscocity breakdown. Just my
Old 05-06-2005, 02:49 PM   #30
Rhymingmechanic
Rhymingmechanic Normal reputation
Re: 15000 mile oil?
From what I've read, the early Oil Life Monitor (like 2001) records things like temperature, rpm, and cold starts, but can't actually test the oil. Mine has come on as early as 3200 with a lot of short trips in cold weather. I changed at 6200 once with a lot of summer highway driving and the light had not come on yet. The OLM is calibrated for dino oil if that's what the truck came with, so the "change oil" mileage will be conservative if you've switched to synthetic.
Anybody considering a "no oil change" program might be interested in the test linked below. They wanted to see how long they could go without changing synthetic oils, and had a sample tested every 1000 miles. They changed filters when "insolubles"--the stuff the filter can't catch--got too high, and changed the oil when the anti-acid additives were almost gone.
http://neptune.spacebears.com/cars/s.../oil-life.html
Edit: The test used regular Mobil 1, not the new extended drain version.
Rhymingmechanic is offline   Reply With Quote
Bookmarks
Google
Web AF
