Old 04-26-2005, 10:52 PM   #1
nasTone
Send a message via Yahoo to nasTone
Talking How To: Shocks in under an hour.
I built some shocks for one of my cars and thought I would put a tutorial together while I was making them. As long as it helps one person I will be happy.
You will need 3/32" dia. and .060" dia. tube along with some 24 ga. wire to complete these shocks.
First, mark and cut two pieces of the 3/32" dia. tube to the desired length. For my model, I thought I would use 3/8". These will be used as the bodies of the shocks.
Next, mark and cut two pieces of the .060" tube. This time, add 1/16" to your previous lengths from step one. These will be used as the shock "rods".
Now, mark and cut four pieces of 3/32" dia. tube at 1/16" of an inch. These will become the shock mouting pieces.
So far you should have eight pieces. Two shock bodies, two shock "rods", and four mounting pieces.
Glue one of the mounting pieces to the to of one of the shock bodies. Glue another mounting piece to the top of the shock "rods". Repeat for the remaining pieces.
Now, cut a length of wire and wind it around a spare piece of 3/32" tubing. Don't wrap it too tightly, otherwise after you paint the shock body, you won't be able to slide the spring in place without scratching the paint.
Cut the springs to the desired length.
Paint you shocks your desired colors. For this tutorial, I painted the bodies black and the rods aluminum. All that is left to do is to slide the spring over the body. Then, insert the shock rod into the shock body.
There you go. Simple shocks in under an hour.
Currently in the shop...
1968 Dodge Charger R/T
1970 Dodge Challenger T/A
1984 Pontiac Grand Prix Pro-Street
nasTone is offline   Reply With Quote
Old 04-26-2005, 11:00 PM   #2
willimo
Sweet, sweet tiny Hondas.
Re: How To: Shocks in under an hour.
Brilliant! Thanks!
Old 04-27-2005, 12:16 AM   #3
tardster
Hey thanks, I was going to do the same thing, but I ran out of rods and havent gotten anymore yet. Great tut though...
tardster is offline   Reply With Quote
Old 04-27-2005, 02:04 AM   #4
tigeraid
Authorized Vendor
tigeraid's Avatar
Great tutorial... just wish my hobby shop had specific diameters of styrene tube so I could do it
tigeraid is offline   Reply With Quote
Old 04-27-2005, 12:44 PM   #5
Ferrari TR
Not A Hoarder!
Ferrari TR's Avatar
nice!
Evergreen sells a tube and rod assortment pak that contains one each of 6 or 7 different sizes. It's perfect for lots of little projects like this.
SCCA 7, The lost Z
Ferrari TR is offline   Reply With Quote
Old 04-27-2005, 12:45 PM   #6
SteveK2003
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
nasTone-
Nice tutorial. You can also substitute polished wire for the shock shafts, to save from having to paint them. And wrapping the spring wire around a wood or sheet-metal screw can help you get perfect spacing for the coils.
tigeraid-
What does your LHS have? I'm sure they can order whatever you need, if you get the part number.
SteveK2003 is offline   Reply With Quote
Old 04-27-2005, 01:18 PM   #7
nasTone
Thanks for the tips Steve. Your method of winding the springs would save a lot of time.
Old 04-27-2005, 04:27 PM   #8
tigeraid
Authorized Vendor
tigeraid's Avatar
Re: Re: How To: Shocks in under an hour.
Originally Posted by SteveK2003
nasTone-
tigeraid-
Well I actually have the Evergreen variety pack full of all sorts of good stuff, but it doesn't have tubes that small. Lots of SQUARE stock that small, but no tubes...
Old 04-28-2005, 07:46 AM   #9
Verminator
Verminator's Avatar
Send a message via AIM to Verminator
Short, sweet and to the point good job will give it a try.
Verminator is offline   Reply With Quote
Old 04-28-2005, 02:16 PM   #10
allparish12
allparish12's Avatar
sweeeeeeeeeet!! U get a lemon to suck b/c ur awesome!!
Trying to ge back into the swing of things...any advice is good advice
allparish12 is offline   Reply With Quote
Old 04-30-2005, 04:23 PM   #11
Jay!
Horizontally Opposed
Added to the list! Thanks!
Hierarchy of Subaru:
(Click to see mine!)
Jay! is offline   Reply With Quote
