Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > How-to/Technical Info
How-to/Technical Info A wealth of information at your disposal.
Thread Tools Search this Thread
Old 04-15-2005, 03:27 PM   #31
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: Facts about steering slop....
Can anyone take a picture of this adjusting screw?
I want to tighten my steering a bit.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 04-15-2005, 04:22 PM   #32
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Facts about steering slop....
Originally Posted by BlazayBlazerious
Yes this post is back! rlith, thanks for an awsome post its given me new hope on what I though was just maybe the way Blazers are, since my current '98 Blazer, my former '98 and my '88 S-10 pickup all suffer(ed) from considerable slop.
I'm pretty square on the rag joint replacement, but how extensive is replacing the box? I'm extremely intrigued by getting one with a tighter ratio.
Direct swap...
rlith is offline   Reply With Quote
Old 05-05-2005, 01:18 PM   #33
blazee
IT'S GOOD TO BE THE KING!
blazee's Avatar
blazee +50blazee +50
Originally Posted by blazee
Back when I was researching before I bought my blazer, I read about some issues where the bolt in the intermediate shaft wasn't tightened and it could loosen up, causing steering slop. It also said that it could fall out and you would loose control. I haven't found any recall info on it. I will search and see if I can find it again and give more details.
I forgot all about this until I just stumbled across it again.
1995 Chevrolet S10 Blazer NHTSA Recall ID Number: 96V195000
Recall Date: OCT 08, 1996
Component: STEERING:GEAR BOX:SHAFT SECTOR
Potential Units Affected: 144598
Summary: THE INTERMEDIATE STEERING SHAFT LOOSENS AT THE STEERING SHAFT TO STEERING GEAR COUPLING. WITH THIS LOOSENESS, THE YOKE PINCH BOLT CAN WEAR ON THE SPLINES OF THE SHAFT UNTIL THERE IS NO LONGER AN INTERFERENCE BETWEEN THE SPLINES AND THE BOLT.
Consequence: THIS CONDITION CAN CAUSE BODY TO CHASSIS MOVEMENT ALLOWING THE STEERING SHAFT TO SEPARATE FROM THE STEERING GEAR WHICH CAN RESULT IN A LOSS OF STEERING CONTROL.
Remedy: DEALERS WILL RETORQUE THE UPPER AND LOWER BOLTS TO CORRECT SPECIFICATIONS.
Notes: GENERAL MOTORS CORP.,
Like this post? Hate it?
<----- Click the and tell me what you think.
blazee is offline   Reply With Quote
Old 05-06-2005, 01:19 PM   #34
Allbert
Allbert Normal reputation
I tried to take a picture with my cheapo digital, but no good. The screw in question is an allen head that is locked down with a hex jam nut (maybe 3/4 or 13/16). It is on the top of the steering gear near the front on what appears to be a square-ish cover plate that is held down by four bolts. I adjusted mine while I had my radiator cover off anyway to change my water pump... it might not be necessary to get this out of the way to do an adjustment on the gear, but I think it made the job easier. It's probably been about 1500 miles since I tightened mine down, and I haven't noticed any return of the steering slop. Of course, I'm not beating the hell out of my steering and suspension with any off-roading in my 2wd.
Allbert is offline   Reply With Quote
Old 05-09-2005, 05:07 PM   #35
s10blazerman4x4
s10blazerman4x4's Avatar
s10blazerman4x4 Normal reputation
Send a message via AIM to s10blazerman4x4
steering box/rack is that what im looking for
its from a camaro and the wrecking yard says it fits is that the same as rag joint
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will. Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
s10blazerman4x4 is offline   Reply With Quote
Old 05-09-2005, 08:48 PM   #36
rlith
rlith's Avatar
steering box is seperate... The rag joint is integral to the intermediate shaft
Old 05-09-2005, 10:59 PM   #37
s10blazerman4x4
but if i take that box then the rag joint intermediate shaft it should tighten it up
Old 05-10-2005, 06:05 AM   #38
rlith
rlith's Avatar
A camaro intermediate shaft won't mate to the steering column... Your best bet is to hit a bone yard and grab one from a 3rd gen trailblazer/envoy Lower miledge...
Old 05-10-2005, 06:53 AM   #39
s10blazerman4x4
alrite will try again
Old 05-10-2005, 07:06 AM   #40
rlith
rlith's Avatar
besides, you should go with a newer zq8 box..(same as the camaro z28 box) because it will also have lower miledge... Was the camaro box you were getting from an Iroc? If not it will be a standard 14.7:1 box and not the 12.1:1 box you're looking for..
Old 05-10-2005, 12:36 PM   #41
blazee
blazee's Avatar
I'm considering renting a trailblazer from one of those $20-$40 a day rental places and swapping out a few parts.
Old 05-10-2005, 02:34 PM   #42
s10blazerman4x4
yeh it was but i will look into this zq8
Old 05-10-2005, 03:42 PM   #43
muzzy1maniac
muzzy1maniac's Avatar
muzzy1maniac Normal reputation
Nice - I like your way of thinking!
muzzy1maniac is offline   Reply With Quote
Old 05-10-2005, 03:47 PM   #44
rlith
rlith's Avatar
Yeah.... theft is cool...
Old 05-10-2005, 05:36 PM   #45
s10blazerman4x4
2003
Steering Rack/Box
Chevy Blazer S10/S15=75bucks low mileage 22000
Still looking for a shaft for the trailblazer
Bookmarks
Search this Thread:
Google
Web AF
