Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > How-to/Technical Info
How-to/Technical Info A wealth of information at your disposal.
Thread Tools Search this Thread
Old 10-13-2007, 09:42 PM   #31
FantasticChadwick
FantasticChadwick's Avatar
FantasticChadwick Normal reputation
Send a message via Yahoo to FantasticChadwick
Re: 98 Blazer heater core replacment (I just did it)
OK, well, like many of you, I too am now in the club. I just finished changing the heater core in my 2000 Olds Bravada.
Have any of you read the book 1984? I never understood toward the end of the book how they broke that man and turned him into one of them. This project has helped me see that. I have submitted to my Bravada. I'm changed. I've stepped through to complete surrender.
OK, so a hot shower and a neck rub will bring me back. Let me get on with throwing in my input.
For starters, I didn't dremel the tabs in the begining. Instead I opted later to use brute force and rip the #$ #@%^#! %&$(#*@ piece of #$*@ heater box off of the firewall. That was of course after removing all the other bolts from the engine compartment.
I didn't cut where it says "Cut here for service", like the post abave mine says, I removed a few extra bolts and folded the soft rubber cover back. I used about a 14 inch extention with a swivel and a 10mm socket to get down inside the little hole in the engine compartment to get the pain in the @55 bolt out. fortunately I have small hands that fit inside there so I could grab the bolt and put it back in upon re-assembly. I have no advice there for you people who can't get your hand down in that hole.
I also didnt undo all of the wiring from the dash. It was a SERIOUS pain the @55, but I didn't want to get into inadvertantly blowing an airbag or some other insanely expensive mistake. It required copious amounts of cussing and stepping back in disbelief that this inannimate object would have the gaul to screw so badly with my world, but with enough wrestling and finagling I was actually able to get the old one out and the new one in. Getting the heater box back in was a chore that would have been made far easier with a second set of hands, but I managed in my restricted state of having only two hands to do the job.
Dash re-assembly was entirely too easy. I still feel as though it was too easy to have been done correctly. The dash seems solid and everything works.
total project time was 4 hours. I couldn't have done it without the first post in this thread. It made little sense before the project, but I printed it and had faith in it. I followed it, deveating only slightly here or there.
Tomorrow I get to replace my balljoints AGAIN for the second time in less than a year. I splurged for the Delco's this time.
2000 Olds Bravada 4.3w, 215,000 (May 09)
2005 Yamaha Vmax 1200cc, 23,500 (May 09)
2004 GMC Sierra 1/2ton 4.8"V", 70,000 (May 09)
1983 Kawasaki LTD KZ750-K1 750 in-line twin 22,000 (June 09)
Although I don't have much automotive knowledge to offer in return for all the help I get from these forums, I am a master electrician, so if anyone needs electrical advice I would consider it my rent here to share. Just PM me.
FantasticChadwick is offline   Reply With Quote
Old 01-04-2008, 11:28 AM   #32
raydulce
raydulce Normal reputation
Looks like a great page. Thanks for the help guys. I will be doing this to my 2001 2 door Chevy Blazer next weekend, so I can try to add my $0.02 after that. Before I start the project though, does anyone have any more pictures of the project? Such as the hidden bolt location (behind the pastic shroud under the hood)? I'm just interested in as many pictures and details as I can get before I start this painful experience. Also, how many wiring harnesses do I have to unplug? Do i have to touch the passenger airbag at all?
I'm not looking foward to doing this...
Thanks though!!!
raydulce is offline   Reply With Quote
Old 01-04-2008, 07:05 PM   #33
FantasticChadwick
Thanks though!!!
I didn't disconnect the wiring harnesses. I didn't fully remove my dash. It would have been a LOT easier to replace the core had I done that, but I had a lot of apprehention about messing with airbag wires, so I toughed my way miserably through removing the old core and installing the new one without removing the dash entirerly.
I don't have more pictures of the project, but if you print the first post in this thread and take a leap of faith into this project you should be able to get through it. Most of the first post made little or no sense, but as I hit problems they were addressed in order in my print out.
I pity you for having this project looming in front of you.
Chadwick
Old 02-13-2008, 03:29 PM   #34
kmlomax
kmlomax Normal reputation
OK, so my dash is off. I've printed the first post in this thread and that helped a lot. I "cut here for service" and got that bolt out (thanks to my small hands). I'm back into the inside of the truck here. There's a large black cover that splits (top piece, bottom piece), then behind that there is the heater core. There also a small cover that snaps into the top split piece (2 clips) on top of the heater core. I've lossened every screw/bolt I can see, and a couple I had to do by feel. I can't get any of these black plastic covers to come completely out. Where all is top piece connected to bottom piece? I undid 7 screws (I counted them just now). I'm yet to see a picture in any manual or post thread that looks like what I'm lookin at. My truck is a 98 Blazer 2Dr, ZR2.
I'm about to resort to the hammer and chisel method here, because I need this thing fixed, and the mechanic wants $700.
kmlomax is offline   Reply With Quote
Old 02-19-2008, 01:16 AM   #35
penn96s10
penn96s10 Normal reputation
What causes the heater core to go out. I've changed the thermastat, radiator, and heater core. A week later the new core starts to leak. Is there a sensor or clogged hose. please help
penn96s10 is offline   Reply With Quote
Old 02-19-2008, 06:13 AM   #36
NINFan
NINFan Normal reputation
my '99 Blazer has an aluminum heater and radiator core. if you use the wrong kind of antifreeze, you can corrode the aluminum. but if it started leaking within a few weeks, i'd be surprised if that's the cause. probably just have a loose connection on a hose. or the core itself was defective, which would suck b/c you'd have to redo the entire job to get the core replaced.
NINFan is offline   Reply With Quote
Old 10-29-2008, 10:29 PM   #37
h2oskier5
h2oskier5 Normal reputation
Well we just pulled the heater box out of a 2000 blazer.. It's a bit different from the 98.
First off, cut the 2 tabs off the bottom.. a must...
Second.. The hidden bolt in the plenum in the evaporator is a bitch.. I cut the "service here" cover.. removed the electric coil device and I can see the bolt but couldn't get on it.. I drilled a 5/8 hole in the front of the plenum being careful not to nick the evaporator.. 10 inch extention, 1/4 inch drive, 10mm socket and it came right out..
Now the 2000 has a top and bottom cover for the heater core.. The fwd (firewall side) 7/32 screws are impossible to get to in the vehicle to split the cover. I removed the whole box and took it apart on the bench. I left the ecu attached to the box.
Three hours to completely remove it all..
Should be a bit quicker going back together..
I'll post some pics of this mess..
And No!!! I'll never do it again.. lol
h2oskier5 is offline   Reply With Quote
Old 10-30-2008, 10:08 PM   #38
skyzend
skyzend Normal reputation
bigdinz - I got a laugh reading your experience. I did my heater core several years ago and my interior dome light has stayed on since. LOL. Everything else worked out .... Turned out the heater fan speed coils also went a little while later on so I would have had to "cut here" anyways.
It just cracks me up about the dome light ... did you eventually fix it?
skyzend is offline   Reply With Quote
Old 11-04-2008, 10:08 AM   #39
bigdinz
bigdinz's Avatar
bigdinz Normal reputation
Hmm, the qoute button isn't working for me.
Skyzend, I'm glad you got a laugh out of my troubles. I always say, no matter how dumb you look or feel if someone is laughing at you it's worth it.
I did finally figure it all out, I think it was a fuze I had pulled for whatever reason.
Sadly my rear main seal (or something close to that) leaked and I got water in my oil. I thought I got it fixed in time but shortly after I got it back from the mechanic it started knocking and it got worse with time. I traded it in on a Chevy Malibu for the wife. The Blazer was good to us and we got our money's worth from it, that's for sure.
bigdinz is offline   Reply With Quote
Old 12-17-2008, 04:53 PM   #40
VanillaGorilla
VanillaGorilla Normal reputation
Great info all of you guys.. My 2000 Blazer is slowly losing heat.. No leaks yet but i will save this thread for the future..
Had to replace heater core in my 95 G-20 back in October..
Thanks again..
VanillaGorilla is offline   Reply With Quote
Old 03-30-2009, 03:03 PM   #41
latunguley
latunguley's Avatar
latunguley Normal reputation
Post Re: 98 Blazer heater core replacment (I just did it)
I am grateful that i found this Forum. I am going to include very detailed pictures of the 2000 S-10 Blazer i just disassembled for a leaky heater core. Yes folks you do have to cut the heater box apart. I used my Kolbalt utility knife and it cut like butter. proceded to unbolt the 5.5mm bolts atop the heater box inside the engine compartment and used a Snap-On racheting screw driver with a Craftsman 3" X 1/4" drive extention with a Craftsman 1/4" Swivel to a 10mm 1/4" socket. Note that the screen mesh prevented my 10mm bolt from falling down in or out at all. Once inside the vehicle to pull out the internal heater box you should see a two 5.5mm bolts again atop the inside heater box? Wrench them out. Flip up the plastic lid and them grab ahold of the heater core hose tubings lift up firmly. You have in your hand. Great Thanks goes out to the original poster of this discussion forum. Sorry folks. I tried to land some great and very detailed pics attached here in? Can't figure out how to do it. So what i am going to do is add them to my myspace account for you all to look at. I'm a welder and mechanic. Not real great at this whole internet thing just yet. Sorry? I should have the posted in a day or two. See them at - (www.myspace.com/Rear_West_Main_Auto)
latunguley is offline   Reply With Quote
Bookmarks
Search this Thread:
Google
Web AF
