| Latest | 0 Rplys |
02-18-2005, 07:50 PM | #1 | |
98 windstar 3.8 oil pressure
my 98 windstar with 86k has started to display the oil warning light at idle after it has been driven about 15 minites. it has clean 10w-30 oil. the light goes out above 1000 rpms. i changed the oil sending unit without effect. where is the oil pump? any suggestions would be greatly appreciated because im scared.
02-18-2005, 09:50 PM | #2 | |
Re: 98 windstar 3.8 oil pressure
The oil filter screws onto the oil pump. The oil pump is attached (by six bolts) to the "front cover" of the engine. The two bolts furthest apart are installed with 10Nm torque... the remaining four bolts with 25Nm torque. There an "o-ring" of sorts between the pump and the cover. The pressure relief valve is part of the pump (I believe).
You may want to look at a replacement pump ... probably avail at AutoZone or NAPA.. before removing yours, just to see what's what. My reference is a '99 3.8. I would think the oil pumps are the same on both models. |
02-18-2005, 10:28 PM | #3 | |
i gather from this that the pump is not in the timing cover, but on it under the oil filter-----otherwise it would involve tearing off the front of the engine (alternator, a/c, etc. If I tried this, the van would have to go to salvage. You have given me hope. Many thanks---Gary
02-19-2005, 11:54 AM | #4 | |
Sorry to say....but the "front cover" and the "timing chain cover" are the same thing. Try visiting www.autozone.com and see if they have instructions for replacing the oil pump. You should not have to remove the front/timing cover....but there is not a lot of room in there.
02-19-2005, 12:54 PM | #5 | |
Space is at a premium, ....but I believe the oil pump is removable, from below, with engine in place.
02-19-2005, 08:44 PM | #6 | ||
Re: Re: 98 windstar 3.8 oil pressure
02-28-2005, 07:36 PM | #7 | ||
Re: Re: Re: 98 windstar 3.8 oil pressure
02-28-2005, 07:46 PM | #8 | |
Did you happen to notice the pressure relief valve? Is it part of the replacement pump? .. or is it a separate item stuck into a recess "under" the pump in the front cover ... and held in place by the pump?
02-28-2005, 07:56 PM | #9 | |
I seem to remember the pressure relief as being part of the pump assembly on the '96 3.8L....from reading repair information.
02-28-2005, 07:58 PM | #10 | |
There is an Oil level sensor also.....I wonder if that is having something to do with this........... |
02-28-2005, 09:19 PM | #11 | ||
03-01-2005, 09:04 AM | #12 | |
The front cover would not have to come off to replace the pressure relief valve... I'm thinking it is sandwiched between the oil pump body and the front cover... and would come loose in the box just like you describe.
It should have been replaced by the mechanic to eliminate that possible problem. My guess is your whole original problem is a broken spring in the pressure relief valve....its the only thing that would "suddenly" give you your symptoms. Go back to the mechanic and insist he address this concern. Of course, IF the pressure relief valve was replaced and IS working then MAYBE there is a pickup tube concern....but I don't believe it! |
03-01-2005, 02:59 PM | #13 | |
12 ounce----the mechanic said he did not replace the relief valve because the front cover would had to come off. the light is tending to stay off more, sometimes just flickering and sometimes staying off, so i guess it is better. the mechanic said he thought the engine just had that much wear, so i will probably just drive it awhile more and see what happens----many thanks for your help, gary
03-01-2005, 03:28 PM | #14 | |
I pretty sure the mechanic is wrong on this issue. I have seen an exploded view (somewhere) that indicated the pressure relief valve is temporarily held in place by a clip-in retainer ... then when the oil pump body is bolted on, the relief valve is finally captured securely. What ever it took... why wouldn't he complete the job?
The pressure sender is telling you there is a problem... please don't destroy your engine! Is there someone out there who has actually replaced the pressure relief valve on a 3.8? |
03-02-2005, 10:46 PM | #15 | |
Well, I presently have my timing cover off and oil pump off. I'll take a look and get back to you. May be this weekend though.
