Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 02-16-2005, 09:15 PM   #16
clagrow
clagrow Normal reputation
Angry I didn't see how to upload it last time...here it is
clagrow is offline   Reply With Quote
Old 02-16-2005, 09:15 PM   #17
jon95se
jon95se Normal reputation
Re: Need to know what this wire set and connector plug in
#1, maybe tach wires if your car doesnt have a tach.
#2. not only can you crop the picture in photoshop cs, but if you click the image toolbar, you can click "image size" and scale it down. and save it in a different jpg compression so that it is even faster to load on the web. or you can send your stuff to me and i will scale em down for you and send em back.
jon95se is offline   Reply With Quote
Old 02-16-2005, 09:25 PM   #18
clagrow
Not the Tach wires
I do have a tach but, it works fine...
Old 02-16-2005, 09:43 PM   #19
kustomkid54
kustomkid54's Avatar
kustomkid54 Normal reputation
Re: Not the Tach wires
Everything on the car working fine? I still say it's a hook up for GM test eq. or something that maybe on other cars but not yours.
kustomkid54 is offline   Reply With Quote
Old 04-13-2005, 08:57 PM   #20
pistons6
pistons6's Avatar
pistons6 Normal reputation
i have an 89 grand prix and there is a plug there that has a red connector on it plugs in at the back near the top by the fire wall
pistons6 is offline   Reply With Quote
Old 04-14-2005, 07:34 AM   #21
jon95se
ambient air temp sensor
Old 04-14-2005, 05:12 PM   #22
notladstyle@yahoo.
notladstyle@yahoo. Normal reputation
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
Re: Re: Need to know what this wire set and connector plug in
no no is a fuel injector plug
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
notladstyle@yahoo. is offline   Reply With Quote
Old 04-15-2005, 07:41 PM   #23
KX2000GTP
KX2000GTP Normal reputation
Send a message via AIM to KX2000GTP
Originally Posted by BIG-L
Id like to know how to down size some of mine...How can I do it???
Remember im an old man and im stupid when It comes to doing that kind of stuff on a PC.Also how do people take screen shot's ..Thanks !
~Larry~
To do a Screen Shot, press Ctrl and Print Screen at the same time when the image you want is on the screen. Ctrl is on the bottom left of the keyboard or the bottom right under the Enter key. Print Screen is on the top row by the F# buttons, to the right.
Just in case you hadn't figured it out yet.
KX2000GTP is offline   Reply With Quote
Old 04-16-2005, 02:01 AM   #24
pistons6
pistons6's Avatar
i will look and tell you where they connect on my car and ill figure out what they connect to i will post an answer tomorow for you
Old 04-18-2005, 09:56 AM   #25
wylie
wylie's Avatar
wylie Normal reputation
Big-L: another way you can do this is
1. open your Windows paint program
2. Then bring up the screen you want the pic of and hit the Print Screen
Key
3. Go bck to the paint program,under file select paste.
After that you can play around with it and save it to differant formats.
wylie is offline   Reply With Quote
Old 04-19-2005, 06:56 PM   #26
ChrisB-98GrandPrix
ChrisB-98GrandPrix Normal reputation
~Larry~
Digressing from the topic here but I feel the need to help Big-L in any way I can (considering how much he helps everyone else).
Photoshop CS is a big and powerful program and way overkill if all you want to do is resize and crop some pictures. Try downloading this...
http://downloads-zdnet.com.com/3000-2192-10021962.html
Infranview is one of many simple picture editing tools. Here are the basics you're looking for...
Rezising the picture -
Once you open the picture [file-->open-->(choose the picture)] you can resize it by clicking [image-->resize/resample-->(choose size)]. There you can either specify the size or simply change the percentage from the original.
Cropping the picture -
Once you open the picture [file-->open-->(choose the picture)] you can crop it (trim the picture down buy cutting off the outside borders). Simply select the area you want to keep. Do this by first selecting the part you want to keep (click then while holding the button down drag to the shape you want). The lines that make the square are where the picture will be cut. Now click [edit-->crop selection]. You're done.
If at anytime you mess it up, just click [edit-->undo] to undo what you just did. Once you're satisfied with the results... save the file [file-->save as]. By "save as" you give it a new name which keeps the original unchanged.
Hope this helps :-)
Chris B
98 GTP
3.4" pulley, DHP v1.0 PCM, Thrasher CAI,
TOG Headers, Random Tech Hi-Flow Cat,
I-Win 1.9 rockers, 90# valve springs, 180 Stat,
Autolite 104 plugs, TB spacer, Poly Motor mounts
Gatorback SC belt
ChrisB-98GrandPrix is offline   Reply With Quote
Bookmarks
Google
Web AF
