02-08-2005, 10:55 PM
#16
Re: Help Help Help!!!
well ok then what is the amount and types of cleaner should i use in my 89 s-10 blazer 4x4 4.3L TBI with over 200,000 miles under the hood?
02-08-2005, 11:04 PM
#17
AF -Advisor
for one, one can would have done the whole job.
1/3 in the tank, 1/3 in the oil and 1/3 through the PCV line.
1995 Factory Blazer Service Manual for sale, PM if interested.
02-08-2005, 11:09 PM
#18
ok you win lol...
02-09-2005, 07:07 AM
#19
i was gonna say just give up blaze he knows whats he doing.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will.  Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
02-09-2005, 08:47 AM
#20
Re: Re: Help Help Help!!!
Originally Posted by blazerboy2005
hay i will dump as much shit that i can buy in this motor to keep it going as long as i can thank you... and hay i think this moter has so many carbon deoposits in it i could flush it 10 times and the oil would still come out dirty
Hold on there Big guy. Do yourself a favor and save a few bucks. With each and every flush you run a risk of dislodging junk from your engine that may ultimately end up wiping out a bearing. I am the first to agree that a flushing an engine can be a good thing. I just flushed mine last night. But I also lost an 1982 Olds V6 engine by using repeated additives. (Threw a connecting rod that punched a 6 inch hole in the block!) I keep the twisted connecting rod on my desk to remind me that more is not always better.
PLEASE do like BlazerLT says and use moderation. You could be doing more harm than good.
You got your truck running good now, Right? As they say in the South, "Let sleeping Dogs lie". If you are heavily dependant on your truck and can't afford to replace it, I wouldn't experiment with it. Keep a good maintenance program going and save your money. If you start having problems, then work towards a fix.
02-09-2005, 03:02 PM
#21
AF -Advisor
Thanks guys, I'm glad people understand that I am only trying to have them clean there engine without damage.
02-09-2005, 08:25 PM
#22
yup she runing good now i think i need a new gasket betwen my tbi and intake is it a pain in the azz or is it farily easy it dosent look to hard
02-09-2005, 08:30 PM
#23
IT'S GOOD TO BE THE KING!
You just can't leave that damn thing alone...can you?
Like this post? Hate it?
<----- Click the  and tell me what you think.
02-09-2005, 10:56 PM
#24
AF -Advisor
Stop screwing around replacing things that don't need to be replaced.
02-10-2005, 08:11 AM
#25
What makes you think you need to replace the gasket? You've told us that the truck is running good, Right? You're gonna end up walkin' to work if you don't quit F@#*ing around with things that don't need to be replaced. Stop while you're ahead!
02-10-2005, 09:04 AM
#26
ok i no its bad beacuse it hisses realy loud
02-10-2005, 09:20 AM
#27
Hisses as in a vacuum leak?
02-10-2005, 01:24 PM
#28
You sure you didn't just forget to re-connect a vacuum line while doing all of the other work. Check out the top of your engine real good before tearing it down
02-17-2005, 04:46 PM
#29
i have a 91 s-10 blazer that had no oil pressure for a long time, i think i had gunk in my oil pan, then i put some seafoam in it and it cleared it right up, so i doubt that that had anything to do with your low oil pressure, my oil is always around 20 at idle and 40 while running, however you have hydrilic lifters and one of them may have bled down and caused it to knock. thats about the extent of my knowledge.
02-17-2005, 04:47 PM
#30
AF -Advisor
How long has the seafoam been in it?
How much seafoam did you put in?
