02-11-2005, 03:24 PM
#16
AF -Advisor
Re: OBDII scanners
1995 with the computer in the engine compartment is a OBDII, just a primitive version of it.
1995 Factory Blazer Service Manual for sale, PM if interested.
02-11-2005, 04:02 PM
#17
Automotive Master
Re: OBDII scanners
AutoXray is good and easy to use, be sure to get the man. specific cables for any OBDI vehicles you want to scan.
02-11-2005, 04:42 PM
#18
AF -Advisor
Re: OBDII scanners
If he has the computer in the engine compartment, he can use the standard OBDII cable.
02-11-2005, 07:26 PM
#19
IT'S GOOD TO BE THE KING!
Re: OBDII scanners
http://www.automotiveforums.com/vbul...d.php?t=361369
If you have the ECM under the hood you can get a computer update that will allow you to use any OBDII scanner.
Like this post? Hate it?
<----- Click the  and tell me what you think.
02-11-2005, 07:36 PM
#20
Re: OBDII scanners
Okay guys, anyone know any reason that you can't make your own cable:
 (info from http://www.scantool.net this will work with their software too)
Then Download the AutoTap software for free at:
http://autotap.com/WindowsSoftware2.html
And have an OBDII scanner for free (other than the price of parts)? There is a warning about connecting it directly to your laptop, because the battery voltage may damage the laptop's port, but if you leave the 9 - 16 wire disconnected it won't have the high voltage. The 9-16 battery power wire is just for displaying the battery voltage...isn't it? All the other wires should only be 5 volts...right? Will this work? Is anyone dumb enough to try it? I'd do it, but I don't want to be the first.
02-11-2005, 10:24 PM
#21
AF -Advisor
Re: Re: OBDII scanners
Originally Posted by blazee
You don't need the update for it.
If you have the 16 pin DLC connector, you can get the codes from a any OBDII scanner.
02-12-2005, 09:35 AM
#22
Re: Re: Re: Obd1.5
Originally Posted by robbjohnso
What is the name/manfacturer of the unit that will flash the SES light?
I am not sure but they sell them at most major auto parts stores.
02-13-2005, 11:12 AM
#23
I got my scanner from obd-2.com a few years back. If you don't have a laptop they will send a connector with extra lengths of cable on it.
I bought one that would work with Ford, Chevrolet, and Dodge vehicles, since we aren't really brand specific here. I first used it on a 95 Mustang, which I suppose would be considered the OBD 1.5, it wasn't fully functional on that car.
Since then I've used it on my Blazer, a Tracker, Dodge Ram Pick Up, a Monte Carlo, and even a Hyundai. I like the program because it has a lot of real-time data on it as well, and not just why the Check Engine light is on. Sometimes the real-time data can help narrow down a hard to find problem.
02-28-2005, 08:20 PM
#24
Re: OBDII scanners
Well, sorry to ressurect this thread, but I think we're gonna start building those cables (as outlined in the diagram) if they work, we're gonna send them out packaged with autotap and some other stuff.
02-28-2005, 08:30 PM
#25
AF -Advisor
Re: OBDII scanners
Just make sure you contact the patent office and check just to cover your bum if someone doesn't like what you are doing.
02-28-2005, 08:32 PM
#26
Re: OBDII scanners
I really would like to know if it will work. The site said not to do it, that this cable should be used for connecting an interface, But it didn't say it wouldn't work it just said it might damage the computer's port.
02-28-2005, 09:11 PM
#27
Re: OBDII scanners
 It won't work. I've read before that you only need an interface to protect the computer from the battery power, but appearently they don't speak the same language either...... http://www.elmelectronics.com/DSheets/ELM320DS.pdf
02-28-2005, 09:16 PM
#28
Re: OBDII scanners
I'll check a little more into that, not hard wiring an IC inline...
