Originally Posted by BlazerLT
Excellent, enjoy your truck.
Well ,not quite done yet! The Blazer is running pretty good right now but I cant connect the four wire pigtail at the distributor! This plug is to be disconnected to set the timing. Once I was done setting the timing, I reconnected it but it wont start up. As long as I disconnect the plug, it will start up like a champ, and run pretty good but As long as that plug is disconnected, the ECM is not able to make adjustments! So, im sure im not getting any spark advance or fuel mixture adjustments from the feedback carb. Ive been told that it sounds like the ECM is bad, but, I am able to get it into diag mode. I figure if the ECM was "dead", that it would be completely shut down right?
