Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 01-06-2005, 04:34 PM   #16
jsteezy1290
jsteezy1290 Normal reputation
Re: 1997 blazer wont start
but im getting a good spark..and the blazer has started twice just not since then. it seems everytime i take the plugs and clean them it will fire up
jsteezy1290 is offline   Reply With Quote
Old 01-06-2005, 04:42 PM   #17
jsteezy1290
the blazer is getting spark though, and has started twice. how do i know its not the fuel regulator? ignition switches arnt cheap i dont want to just buy a part and have it still act up
Old 01-06-2005, 06:03 PM   #18
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
*Sigh*
Do what you want, I could care less now.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 01-06-2005, 10:27 PM   #19
crazys182003
crazys182003's Avatar
crazys182003 Normal reputation
if you were to check out this entire forum about 97 blazers if there is a problem and it can't be solved than check the ignition switch. I don't have a 97 but I have been watching this forum ever sicne I joined a couple months ago. Also Blazer LT does know what he talks about. I used to be bullheaded also as to doing soem work on my vehicle but now been finding out that maybe I shoulda done more maintance and check out everything right away that people suggest. I just found out recently that my 4x4 system is not working correctly well it goes back to when I joined this forum. It was due to flooding ym engine and I forgot to drain my 4x4 system now I need to. Found out it is ratehr nasty and it is getting changed. If only I ahd checked out what peopel suggested sooner it wouldn't have caused me as many headaches. But believe what you want to.
crazys182003 is offline   Reply With Quote
Old 01-06-2005, 10:42 PM   #20
jsteezy1290
i dont know what to do, i jumped in it tonight and it fired right up.. and has a little miss to it but none the less it runs. seems to start up fine. i looked at the switch and it looks like its been replaced already. i seem to be having a problem with turning the key and getting it out the column
Old 01-06-2005, 11:00 PM   #21
crazys182003
Re: Re: Re: 1997 blazer wont start
If your key isn't coming out properly and giving you trouble like you said maybe it wasn't changed or maybe it needs changed again. I know you said it looks changed but did you in fact have that work done? Don't assume other people did the work for you. Also it may be starting now but you have also said in a previous post
Originally Posted by jsteezy1290
yea its not the fuel pump, cause i drove it yesterday now it going back to the same old thing
How do you know it isn't just happy right now and starting and not gonna cause a problem another day?
Old 01-07-2005, 12:30 AM   #22
JackDaniels386
JackDaniels386 Normal reputation
well, if your spark plugs get wet with fuel, Blazer LT is right and you dont have the spark to ignite it. It might be your distributor. Check for spark on the wire from the coil to the distributor, if you have spark there, then check each wire from the distributor to the spark plugs 1 by 1 and make sure theyre all getting spark.
JackDaniels386 is offline   Reply With Quote
Old 01-07-2005, 02:11 AM   #23
imnprsd
imnprsd Normal reputation
Originally Posted by BlazerLT
Because the ignition switch controls the ignition and spark, you aren't getting the spark for the fuel, hence the wet plugs full of fuel.
Comment/Question: I did some checking on this ignition switch. For clarification, and this is a question for the experts out there, the ignition switch it's not the key/tumbler. (Right?) The ignition switch is the ~foot long wiring harness in the steering column and it costs about $130 for the part alone... And as for the fuel pump relay, that is located in the glove box.
Question: In a previous thread there was talk about wiggling the "pink wire" which presumably goes to the fuel pump. What more can you say about this?
Question: If the ignition switch is such a problem in '97 Blazers (like the one I own) what can you do to correct the problem without buying a new $130 switch? I mean, if the harness is not assembled right or that over time the pink wire ends get corroaded, can it be cleaned or repaired? This might be especially helpful if you are stuck out in the middle of no where.
imnprsd is offline   Reply With Quote
Old 01-07-2005, 02:18 AM   #24
BlazerLT
AF -Advisor
BlazerLT's Avatar
I'm pretty sure you can buy the black module alone.
But there is no way around the switch replacement.
You gotta pay to get the truck running properly.
Old 01-07-2005, 03:11 AM   #25
imnprsd
Are you saying you can buy just the back module on the end of the wire-harness? Sorry, I have not taken it apart. I have only seen a drawing of it at the auto parts store. Thanks for your advise. I'm sure I speak for a number of us S-10 owners when I say, "I appreciate your help."
Old 01-07-2005, 09:05 AM   #26
jsteezy1290
how do you unconnect the wires to the module
Old 01-07-2005, 10:34 AM   #27
BlazerLT
AF -Advisor
BlazerLT's Avatar
I believe from what I have heard that there is a couple of screws holing it in place.
Old 01-07-2005, 07:12 PM   #28
jsteezy1290
i took the black box out is that what needs replaced?
Old 01-08-2005, 02:33 PM   #29
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yes, small black module.
Check to see if the contacts are corroded. If so clean them and reinstall and it might fix it temporarily.
Bookmarks
Google
Web AF
