Yo, 'Stang -
No updates to this bad bitch?
One thing everyone who's working on this kit should watch out for: Testors bobbled the order of the belts, at least in the initial runs of this kit. There's a large, a medium, and a small belt. Testors tells you to use the medium belt as the flywheel drive belt for the electric motor in the base; the small belt, for the crank, alternator, and water pump; and the large belt, for a circuit around the alternator, power steering pump, and crank.
UH-UH.
You want it to look like a real hemi and actually
work, here's whatcha gotta do:
LARGE BELT: Flywheel drive belt.
MEDIUM BELT: Alternator, crank, and water pump/fan pulley
SMALL BELT: crank and power steering pump ONLY.
More here:
http://www.scaleautomag.com/sca/comm...?TOPIC_ID=9721
Also, there's been some speculation about the firing order/ignition wire sequence Testors gives you, but the research a few other modelers and I have done indicates they are in fact correct.
The rest of the model goes together very well and works as advertised. I'd recommend it without reservation.
____________________
Cute signature by the way. I was in your camp once. But things look decidedly different from where I am now...
