Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 01-19-2005, 08:04 AM   #16
vtmecheng
vtmecheng Normal reputation
Re: Missing anti freeze?
BTW...I am only guessing the leak is into the intake because he has already said there are no leaks from any hoses, the radiator, or any where around the intake manifold. That doesn't leave too many options, unless it is dexcool.
vtmecheng is offline   Reply With Quote
Old 01-19-2005, 11:20 AM   #17
FishOn2075
FishOn2075 Normal reputation
Don't forget to check the passenger floorboard for wetness. It's possible that you heater core may be leaking as well.
FishOn2075 is offline   Reply With Quote
Old 01-19-2005, 05:21 PM   #18
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
The liquid is going to displace the air in the system.
This is not a hard thing to wrap the brain around.
I too had this same problem and the cap solved it and I had to add coolant to the system.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 01-21-2005, 12:57 PM   #19
vtmecheng
That makes no sense at all if he is getting air into the cooling system. The system is designed to not have air in it, liquid only. If air is sucked in then the air is displacing the coolant, air comes in causing coolant to stay in the overflow tank. I can understand adding fluid if you go from a bad cap to a good one because your engine will be able to suck up coolant from the overflow instead of air from the atmosphere, requiring more coolant. As said before, if air is in the system it will take up space normally filled with coolant.
Old 01-21-2005, 01:29 PM   #20
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yes, and after a while, it won't require refilling anymore when all the air is out.
Old 01-21-2005, 01:42 PM   #21
vtmecheng
So it seems we are in violent agreement.
Old 01-21-2005, 01:54 PM   #22
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yip.....
Now shut up.....
...I kid..I kid....
Bookmarks
Google
Web AF
