Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 12-29-2004, 11:49 PM   #16
decoy86
decoy86 Normal reputation
Was your original leak?? on the rear of the engine or the front. I am glad I resealed the Intake manifold on my 99 tahoe. It was a mess.. I cant beleive it was running in the shape it was in before the re-seal..
decoy86 is offline   Reply With Quote
Old 12-30-2004, 02:40 AM   #17
skipr
skipr Normal reputation
Re: Re: Intake Manifold..... anyone? anyone?
Originally Posted by kavin
I am fixing my 98 do you know the torque steps and foot pounds for the lower intake. my intake leaked antifreeze in to my oil. thanks
If you need the visual (a top or engine view) bolt tighten sequence, Give me an e-mail and i'll send to you in JPG format or BMP format. i'll include the upper sequence too.
skipr is offline   Reply With Quote
Old 12-30-2004, 11:05 PM   #18
kavin
kavin Normal reputation
thanks for the torque info. i got it back together . and now my water pump is not pumping. it was a new one about 6 months ago . any help on why it is not doing the job now?
kavin is offline   Reply With Quote
Old 12-30-2004, 11:14 PM   #19
decoy86
Is the serpentine belt on correctly??
Old 12-30-2004, 11:43 PM   #20
skipr
how do you know it's not pumping? It's not moving externally? No pressure build up? No hot water entering radiator? Someone Correct me if i'm wrong but isn't the water pump shaft/propeller a solid piece. If its turning on the pulley the impeller should be turning inside.Did you maybe block any of the passages and forget to remove upon re-install.
Old 12-31-2004, 06:12 PM   #21
Riche
Riche Normal reputation
O.k. 10 Hrs. later and lower intake manifold gaskets installed I have no leaks....
I have one thing to say. Beware of the heater hose coupler at the front pass. side if the intake. Extremely brittle!!!!!!!!! I barley put ant torque on it and it snapped off.....
It was a good thing b\c it made me have to remove the lower intake to remove the remaining coupler. When I got the intake off I saw that the gaskets were in bad shape if they were not leaking they would be soon!!!!! Thanks for the help guys...
Riche is offline   Reply With Quote
Old 12-31-2004, 07:09 PM   #22
BobM46128
BobM46128 Normal reputation
Originally Posted by Riche
guys tell me what you think.... upon tearing everthing apart I noticed the radiator hose at the thermastat was leaking. And the heater hose's rubber gastket on the front passenger side of the motor looked a little dryed out... I think I may repair those and put everything back together and give that a try before I pull the intake. what do yall think?
Go for it! I was also ready for the dreaded intake fix when I found it was only the water pump! And now the coolant is a pleasant green!
BobM46128 is offline   Reply With Quote
Bookmarks
Google
Web AF
