Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > Toyota > Previa
Thread Tools Search this Thread
Old 12-08-2004, 10:05 PM   #1
3stews
92 Previa No Spark *** Help please
My 92 previa has lost spark, I have battery voltage to + side of coil and 10.8v durring crank. I have put a test light to the - side of coil durring crank and it flashes lightly. The coil resistance values are right to spec .5ohms primary and 11k secondary. The coil wire has only 3k resistance in it. The distributor pick up coils are within resistance ranges and all of the wiring in the circuit has good continuity. And yes the distributor is spinning. I replaced the ignitor. Tested another ECM. Nothing... I am at a loss as where to go from here???? Can a coil with normal resistance and no visible signs of trouble be weak?
I tried holding the coil wire while the engine cranked and there is a weak spark, enough to hurt, but not enough to arc to ground.
ANY HELP PLEASE......
3stews is offline   Reply With Quote
Old 12-17-2005, 03:45 PM   #2
lisamac
Re: 92 Previa No Spark *** Help please
I'm having the same trouble, can you tell me where's the Ignitor is it in the distributor. Have you fix yours yet.
lisamac is offline   Reply With Quote
Old 12-23-2005, 11:50 AM   #3
Grumoly
[Hello all - new to forums but when I read this I thought I might hav a suggestion.
Just this weekend I was trying to clean my MAF Sensor ( on the top of the air filter box) and I damaged it - the result was that there was no spark. Replaced with one from a wrecker and all is OK. - Maybe your MAF Sensor is bad? Watch out though - I don't believe it will come up with a trouble code at Toyota. They spent 3 hours nearly and didn't check it like I asked because no code came up - when I insisted they found it to be the problem.
Hope this helps.
Grumoly is offline   Reply With Quote
Old 12-23-2005, 04:47 PM   #4
lisamac
Re: Re: 92 Previa No Spark *** Help please
I couldn't verify that the MAF is the problem, when the EFI fuse blows there's No Power at it, because the power to it has to go thru the EFI Main Relay and thru the Circuit Opening Relay and then to the MAF
The EFI fuse blows even if the EFI Relay and Circuit Opening is removed when you turn the key On.
I appreciate your respond and if anything should come up in your mind,am willing to listen and learn. I'm at total lost finding this problem.
Thank You and Merry Christmas/Happy New Year 06
Old 12-30-2005, 01:13 AM   #5
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Yes, the coil can be disfunctional and still show good resistance. There is a big difference between resistance using a 9V test probe and handling 20 kV without breaking down.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 12-31-2005, 09:54 PM   #6
lisamac
Re: Re: Re: 92 Previa No Spark *** Help please
HI
Located the problem: The Orange/Black wire is shorted to the Black/White taking out the EFI fuse and disabling the Main Relay at the same time. Thanks to all that Help.
Old 12-31-2005, 10:08 PM   #7
Brian R.
Resident Chemist
Brian R.'s Avatar
Good Job!
Old 01-13-2006, 06:04 AM   #8
lisamac
Have you fix the problem with No spark?-if not come on back and I'll help you
Old 01-13-2006, 07:28 AM   #9
Brian R.
Resident Chemist
Brian R.'s Avatar
Not likely - that post is a year old.
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
