Go Back   Automotive Forums .com Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 12-03-2004, 02:08 PM   #1
luckykl
Turbocharged R34 RB20DE engine
someone that has turbocharged the 2.0L r34 skyline,
any project details and results from the project ?
luckykl is offline   Reply With Quote
Old 12-03-2004, 03:58 PM   #2
GTES-t
GTES-t's Avatar
Re: Turbocharged R34 RB20DE engine
Never seen a non-turbo'd RB20DE converted. It's just not worth it. The compression ratio/cylinder head/ecu/etc. are not designed for turbo, so it can only take ~6psi at most and requires to much work for it.
The prefered option is just to swap the engine for a turbo'd RB of choice or affordability.
1990 Skyline GTE/S-t 4 Door Updated 6 Mar
Swapped out RB20E with RB20DET
Trans converted from Auto to 5-Speed...
Now with SR20DET 5-Speed
Installed Type M 5-lugs and brakes, R32 GTR rims and 2-Dr rear end (Tail lights & bumper)
1994 Isuzu AMU
US Spec Amigo with JDM Isuzu MU (Mysterious Utility, as it's called in Japan) nurf bars and hatchback style hardtop.
GTES-t is offline   Reply With Quote
Old 12-04-2004, 12:14 PM   #3
RazorGTR
Skyline Man
RazorGTR's Avatar
Well I've seen it done on an R32 and R33 RB20DE and RB25DE motor but not an R34. I would imagine it is the same exercise there. Generally the head gasket is changed to a metal one of 1.2mm thick or thicker to help decompress the motor a bit more. Also the ecu, fuel pump, exhaust manifold, hosing, pluming for the turbo, intercooler, sometimes cams (N/A cams have more overlap which isn't good for turbo cars), then retuned.
Some results have been staggering some were not so good depending on the tuning, what was done. The best I've seen was an RB30DE done and dropped into a R32 GTS4 and it ran low 10's producing over 575hp, but on the flip side the increases were ok. Generally the performance levels were simular to a turbo with nothing done to it (factory turbo used). Overall it cost a lot more than it would have cost to sell the N/A and buy a turbo model.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
RazorGTR is offline   Reply With Quote
