Go Back   Automotive Forums .com Car Chat > Racing > Driving Style and Technique
Driving Style and Technique Got a favorite way to enter a corner? Discuss all things related to piloting a race car here.
Old 12-01-2004, 10:32 PM   #1
terlaje
Cool preferred drag racing transmissions
For a pump gas drag car, what is the preferred type of transmission? The 2005 stang comes w/ either a standard or 5 speed auto trans.
terlaje is offline   Reply With Quote
Old 12-03-2004, 11:19 PM   #2
big dude1
5 speed manual duh lol there is no such thing as a stupid question...
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
big dude1 is offline   Reply With Quote
Old 12-05-2004, 07:44 AM   #3
tanly03
Re: preferred drag racing transmissions
although with the auto, you dont have to worry about shifting the right gears just put the pedal to the floor and drive like a bat outa hell but you wont have the initial acceleration or high end speed as if you would have with a manual. you wont get as good MPG as you would with a manual (taking you are going to drive the car on the streets and not gun every time). You are talking about making your car a drag, you got to match the drivetrain strength with horsepower and torque rating. If you are going to make the car put out close to 500 HP then i would suggest getting the TTC T-56 6-Speed Manual w/11in Clutch from the 04 mustang cobra. if you are going to make more HP than that then you should really invest in a strong and sturdy tranny or you would just be wasting money and time when you drop the tranny in the middle of the run.
tanly03 is offline   Reply With Quote
Old 12-09-2004, 11:39 AM   #4
BlitzKeg
BlitzKeg's Avatar
just stupid people.
BlitzKeg is offline   Reply With Quote
Old 12-13-2004, 12:58 PM   #5
Andydg
Not necessarily, I've seen plenty of autos whoop up on manual cars.
Check out this thread plenty of respectable people backing up the performance of auto trans. and explaining it better than I ever could.
Andydg is offline   Reply With Quote
Old 12-14-2004, 05:59 PM   #6
Forkliftguy
Forkliftguy's Avatar
If you're planing on drag racing the car it would make no sense to go with a 6 speed tranny. All the time you waste shifting could add precious 1/10ths to your final time. Remember that every shift you make causes your car to lose momentum, even if for just a fraction of a second. Sometimes that's all that's needed to lose a race. I'm not a big fan of automatics, but one reason they smoke some manual cars is probably for the fact the tranny will usually only shift from 1st to 2nd by the time it crosses the line, whereas with a 6 spd man you might shift right up into fourth.
Just my .02cents
Forkliftguy is offline   Reply With Quote
Old 12-14-2004, 10:17 PM   #7
AWP9521
I ran a 1979 Mustang for 5 years with a C4 that was built by a company called Trans-King, it had a reverse manual valve body (P-R-N-1-2-3) and a Trans Brake, they also did up a custom Converter for us, a 3800-4000 stall unit that bolted to an AOD Flexplate. We used a condenser coil from an old window air conditioner and an electric fan for the tranny cooler, never drained the fluid in 5 racing seasons and it is still a nice red color.
AWP9521 is offline   Reply With Quote
Old 12-14-2004, 10:45 PM   #8
Andydg
Re: Re: preferred drag racing transmissions
What exactly is a trans brake...I've heard of it but I don't know exactly what it does???
Old 12-15-2004, 11:26 PM   #9
benchtest
Terlaje, Autos are generally more consistent and a bit easier on the drivetrain. Manuals usually offer more gear ratios. So, if you have a very narrow-banded engine, then you will have to use a manual to stay in the powerband. If you have a wide-band engine, then you don't need all those gears (are you old enough to remember big-blocks and powerglides?). Your ability to shift consistently and quickly will also affect the decision to go manual. If you run a turbo car, you'll probably run better with an auto, as it will stay spooled between shifts. There are many factors to consider.
Andydg, A trans-brake engages 1st and reverse at the same time, locking the transmission.
benchtest is offline   Reply With Quote
Old 12-16-2004, 03:26 PM   #10
Blazedout06
Banned
Send a message via AIM to Blazedout06
to make an automatic car as fast as a manual is more expensive and time consuming...and u can't beat on it...
vinny ten supra is auto...but the guys has a thousands of dollars worth g3 or g4 transmission or sumthing...
if u got the money u can do it...
but to learn the fun of drivin u need manual..
or u can sit like a bitch with ur foot on the pedal..
any car..auto and manual..after u take into account the gear shiftin and all that...manual is always faster..atleast by .01-.02 seconds...
ALWAYSSSSSSSSSSSSSSSSSSSSSSSSS!
Blazedout06 is offline   Reply With Quote
Old 12-17-2004, 11:44 AM   #11
Andydg
No...not always.
Old 12-21-2004, 12:43 PM   #12
Blazedout06
Banned
man if u know how to drive...ALWAYSSSSSSSSSS!
u get 1 driver..and have them drive both the stick and the auto...
the stick will be faster!
have u ever seen any brand new car's specs..for auto if the car comes stick????
NO...the specs are always for standard tranny!
Old 12-21-2004, 12:50 PM   #13
Andydg
What does that prove??? Autos will always shift faster and you never have to worry about missing a shift.
Old 12-21-2004, 09:01 PM   #14
SR20DETpower
Banned
Send a message via AIM to SR20DETpower
Ls1 camaro's are faster in the 1/4 stock with an automatic
automatics don't cost a lot to rebuild, factor in your lil t56 transmission, stock oem quality clutch and labor is around a 1000 bucks. Then you also have to rebuild those, new bearings, synchros, input or output shafts... which are also expensive for a t-56.
you can take a th400 with the right parts its stronger then a t56, and will be faster for sure in a drag race as with a car with all the other variables the same besides the transmission.....
i work at a transmission shop
SR20DETpower is offline   Reply With Quote
Old 12-22-2004, 02:36 PM   #15
Andydg
See...not alwayssssssssssssss!!!
