Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee
Thread Tools Search this Thread
Old 10-19-2004, 10:41 PM   #1
tbone47129
89 wont start and its getting spark and fuel
I have had my 89 civic 1.5L for about 6 months I havent had a bit of trouble except for a blown head gasket.Any way the other night it started to stall out and not run worth a shit.I turned it off and restarted it and it ran fine.It set over night and the next morning it ran fine.I drove it around my work.Which is only about 2 miles.I shut it off and it wouldnt restart.It would try to start but it wouldnt.So I read the ecm codes .Which led me to a bad fuel injector.And It still woundnt start after I replaced it.It is getting fuel.You can smell it when you try to start it.I thought maybe the timing belt slipped.But It is in time.And it has a bright blue spark at the plugs.I don't know what to do. I am a chevy man and I know nothing about hondas.Im getting tired off screwing with it.I would just sell it and end it,but I dont have the money for something else.Any help would great.
Thanks,Tim
tbone47129 is offline   Reply With Quote
Old 10-19-2004, 10:45 PM   #2
1PhatCX
1PhatCX's Avatar
can you hear the fuel pump come on?? if not then its the main relay prolly
1PhatCX is offline   Reply With Quote
Old 10-19-2004, 10:53 PM   #3
tbone47129
I have checked the main relay and it is good.I can hear the fuel pump.I wish it was that easy of a fix.
Old 10-19-2004, 11:27 PM   #4
Cjz89civic
AF Premium User
Cjz89civic's Avatar
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: 89 wont start and its getting spark and fuel
could be timing if your belt jumped you can get fuel and spark but no firing. Also have you taken off the dist cap? if so maybe you put on the rotor 180 off (its happened to somebody I know crappy autozone rotors) or it could be your rotor screw has backed out cause it to move also. Ok one more thing the dist cap could be full of carbon like spider webs inside the dist call carbon traces. If any of these are true repace the parts.
If its your timing check the belt to see if any teeth are missing, If you know where your timing mark is on the lower belt pulley ok ex. looking down [ l l l l ] the one on the right is your static the 3 on the left are you running timing. Line up the one on the right to the arrow off the block. Then look up at your cam gear there are two marks that oppose each other and the word "UP" Up should be up if it is not crank the motor over till the UP is UP the two marks have to be straight accross lined up with the head. If they are then your in time on the timing belt. If its not in time do a search on timing thru the forums. HMMMM if this is confussing hehe sorry.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Cjz89civic is offline   Reply With Quote
Old 10-19-2004, 11:57 PM   #5
91civicDXdude
91civicDXdude's Avatar
Re: Re: 89 wont start and its getting spark and fuel
Originally Posted by Cjz89civic
If its your timing check the belt to see if any teeth are missing, If you know where your timing mark is on the lower belt pulley ok ex. looking down [ l l l l ] the one on the right is your static the 3 on the left are you running timing. .
the one on the right is 0 BTDC and the other three are marks for 14, 16, and 18 BTDC. the ECU uses 16 BTDC as its base timing so 16 degrees or the middle mark is your "running timing"
91civicDXdude is offline   Reply With Quote
Old 10-20-2004, 12:39 AM   #6
Cjz89civic
AF Premium User
Cjz89civic's Avatar
ya thats what I meant but it was in easy terms. lol blah I was just rambling.
Old 10-20-2004, 07:53 AM   #7
johnb16a2
johnb16a2's Avatar
Did the rotor screw fall out?
johnb16a2 is offline   Reply With Quote
Old 10-20-2004, 11:19 AM   #8
tbone47129
I have checked the dist cap and rotor and they look good.And I made sure it is in time.When you have the #1 plug out and crank it over it sparks when the cam gear UP mark is in the up position.That means its in time doesnt it? thanks for your help.keep it comming I need a car so I have to get it fixed soon.thanks,Tim
Old 10-20-2004, 05:24 PM   #9
tbone47129
would the electric load control unit being bad cause this problem?Because the electric load control unit smells fried.thanks
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
