Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > How-to/Technical Info
How-to/Technical Info A wealth of information at your disposal.
Thread Tools Search this Thread
Old 02-28-2005, 02:23 PM   #91
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: 1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!!
Very true, good point.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 03-28-2005, 12:01 AM   #92
91s10blazer
91s10blazer's Avatar
91s10blazer Normal reputation
Send a message via AIM to 91s10blazer Send a message via MSN to 91s10blazer
Will this clunk fix work on the 1st gen. Blazers as well? I have a '91 and the sound of it is almost identical to what you guys are saying but it sounds like all your Blazers are 2nd generation.
1991 Chevy S-10 Blazer 4x4 4.3L
http://www.cardomain.com/id/91s10blazer
Visit my site and leave me a comment!
91s10blazer is offline   Reply With Quote
Old 03-28-2005, 12:16 AM   #93
BlazerLT
AF -Advisor
BlazerLT's Avatar
It will be that, or the torsion bar mounts for the first gen.
Old 05-31-2005, 02:43 PM   #94
Big_ Easy
Big_ Easy Normal reputation
Re: Re: 1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!!
Originally Posted by Alexxn 00 Si
Just got mine...I'll let everyone know when they are installed....
I just got back from the dealer and they do not have the part listed. Do you have the number which you could pass on, much appreciated.
Big_ Easy is offline   Reply With Quote
Old 05-31-2005, 03:01 PM   #95
blazee
IT'S GOOD TO BE THE KING!
blazee's Avatar
blazee +50blazee +50
12383460 Washer - Hood Hinge
Like this post? Hate it?
<----- Click the and tell me what you think.
blazee is offline   Reply With Quote
Old 05-31-2005, 03:59 PM   #96
Big_ Easy
Thanks for the quick response much appreciated.
Old 06-01-2005, 03:33 AM   #97
DjEarth
DjEarth Normal reputation
Always wondered what that was. New project for tomorrow I see.
Ordered the washers this morning. $3.00 at my dealership and he wanted to know exactly why I wanted them. Then said..oh that may fix it..but most likely not.
DjEarth is offline   Reply With Quote
Old 06-03-2005, 11:25 PM   #98
Raijek
Raijek Normal reputation
Send a message via MSN to Raijek
Originally Posted by xokayxo
Part number would be the same anywhere though, right? I'm in Alaska. Didn't have time to go to the dealer today so I'll go by tomorrow. Also, I downloaded divX and watched that video, took off the black trim/cover where the hinge is on my Jimmy, wedged in a shop towel, and test drove it. No sound whatsoever. So I drove home and took out the towel, replaced the trim/cover, and I've been driving it unfixed since. AND I'M NOT HEARING IT ANYMORE!! I did the washboard thing again and there was nothing. I thought maybe since it's so cold the metal might have contracted so it's tighter now. Is it still a good idea to replace the washer so it doesn't come back or get worse later, or should I save my time?
No dude! Metal doesn't expand and contract that much But who knows why it stopped. Good tho'
Raijek is offline   Reply With Quote
Old 06-08-2005, 12:41 PM   #99
freddie cosme
freddie cosme Normal reputation
Are these special washers that need to be purchased at the dealer are they nylon or steel
freddie cosme is offline   Reply With Quote
Old 06-17-2005, 09:30 PM   #100
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yes, they are metal.
Old 06-20-2005, 10:34 AM   #101
Lt_Dusty
Lt_Dusty Normal reputation
Angry
Hello to all. I'm new to this site, and have been searching for a cure for the clunk I've felt in the passenger floorboard (on take off, and generally right hand turns), on our 96 Blazer 4x4, for nearly a year. Ball joints, sway bar bushings, idler arm, messing around with the torsion bar mounts, and even the 7 dollar spring washers, with no fix. Although they were in need of replacing anyways. I read a suggestion (i thought was from this thread, but I cant find the post), about re-torqueing the upper A arm bolts. I had been told by numerous suspension experts, the A-arm bushings were fine. Well it seems over time the rubber from the bushings tends to shrink, allowing the a-arm to move back and forth just enough to make a clunk. I loosened the a-arm bolts allowing a little seperation, and hosed it down with white lithium grease, then re-torqued to specs. It not only cured that clunk, but another that I would sometimes get hitting pot holes, or going over rough pavement. Anyways, i thought I would post this for the people that haven't found their cause. Maybe it will save someone a couple hundred bucks.
Dusty
Lt_Dusty is offline   Reply With Quote
Old 06-21-2005, 07:19 PM   #102
metallica21156
metallica21156's Avatar
metallica21156 Normal reputation
i still have a clunck in my 95 that nobodys been able to fix. lower and upper ball joints ,anti-sway link kit and bushings have been replaced,shocks replaced, entire front ends has been gone over and its still there. hood fixed as well and its still there. took it to a friend of mine and him and his mechanic could find anything rubbing or anything that looked like it was hitting. i looked at it my self and couldn't find anything. i've also played with the torision bar cross member and its not from there either. any ideas?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series split rear, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers. Mag 500's with black center caps, C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
metallica21156 is offline   Reply With Quote
Old 07-27-2005, 08:59 PM   #103
ace3
ace3 Normal reputation
Im so glad I found this thread, Ive been chasing this clunk for weeks now .Ive spent 800 on front end parts. I hope this solves my problem....
ace3 is offline   Reply With Quote
Old 07-27-2005, 09:14 PM   #104
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yea, this is what happened to me too.
Old 07-28-2005, 12:44 PM   #105
Cailen
Cailen Normal reputation
I vote this gets stickied
Cailen is offline   Reply With Quote
Bookmarks
Search this Thread:
Google
Web AF
