| How-to/Technical Info A wealth of information at your disposal. |
07-11-2007, 04:13 PM
#166
AF -Advisor
Re: 1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!!
Originally Posted by snoboy
BlazerLT thanks a bunch for showing us this fix. I ordered the washers last week from the dealer and installed them today. I test drove the truck and drove on some choppy stretches of road to double check the washer fix worked! My wife's 2001 Blazer no longer needs an entire front end rebuild. Man you saved my bacon. Thanks again.
snoboy
Glad to have helped you.
1995 Factory Blazer Service Manual for sale, PM if interested.
09-06-2007, 03:03 PM
#167
Bravo!
I have had this clunk in my 2000 Blazer ZR2 since it was new. I always felt it was a hinge problem, but never took the time to solve it. I was even thinking it could be something loose under the drivers side dash panel. I will be doing this repair soon!
-Mike
http://www.sblazer.com
Spare Tire Drop Adapter Kit for 2 door Blazers with factory spare tire carrier rack:
* Increased visibility out rear window
* Lift glass opens past spare tire (try that on a stock Blazer)
* Easy access to the rear cargo area (without swinging carrier open)
* Complete bolt on kit
01-16-2008, 10:43 AM
#168
Originally Posted by BlazerLT
There is the part number listed in this thread.
I suggest reading through this thread, all the info needed is there.
Before I get Flamed....I read the thread (tried dead old links and all  ) but I can not find the part number for the washer......anyone mind helping?
Thanks all!
01-16-2008, 10:50 AM
#169
Thanks all!
Never mind  ....third time looking....many questions with flaming remarks made me miss it....I found it this time
02-25-2008, 08:06 PM
#170
Bumping an old thread but I just wanted to say thanks. I was about to start ordering parts to try and fix the thumping. But i found this thread, went to the dealer and no more thumps. Now i just have to figure out why its running rough, and I fear that its the spider assembly
02-25-2008, 09:48 PM
#171
AF -Advisor
You are welcome.
If the check engine light is on and the engine won't idle, but will run ok on the road, you have to clean your egr valve which is right under where the plastic intake attaches to the engine.
It will fix the issue.
02-25-2008, 10:45 PM
#172
No check engine light. It just seems to run rough at idle and it seems to be getting crappy gas milage. I just found out through more research that I might be able to get away with just replaceing the valve instead of the whole spider.
03-07-2008, 08:18 PM
#173
Will replacing the solinoid for the automatic transmission, be a cure for the transmission not shifting?
03-08-2008, 10:59 AM
#174
AF -Advisor
Yea, the regulator will need to be replaced.
just remember that the longer you drive it like this, the more damge the gas in the oil will do to your engine. I would still remove and clean the egr as well while you have the upper plenum off and replace the EGR gasket.
#175
AF -Advisor
Please start your own thread on this.
03-13-2008, 07:06 PM
#176
AF -Advisor
Here is the video uploaded to google.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/97PUO-BDM0o&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/97PUO-BDM0o&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
03-13-2008, 07:07 PM
#177
AF -Advisor
03-13-2008, 08:01 PM
#178
GM S-Series Mod
LT, is that part still availible at dealers? i'll have to test my truck to see if i have that dreaded rattle.
2000 Chevy Blazer ZR2
Performance: AEM intake, TB mod, ported stock y-pipe w/precat deleted, 3in catco cat, 2.5in Flowmaster 40 DF,
March pulleys, MSD SF ignition, Taylor 8.2 wires, Transgo shift kit, Corvette servos, B&M trans cooler.
Suspension: Knaffle 1.5in lift shackles, 1.25in rear wheel spacers, 31in BFG AT's
Exterior: custom ZR2 decals, bug guard, vent visors
Interior: Lanzar headunit w/ ipod input, Pioneer speakers, Scanguage II
http://www.cardomain.com/ride/3013891
03-13-2008, 08:02 PM
#179
AF -Advisor
I can't see why not.
03-13-2008, 08:10 PM
#180
GM S-Series Mod
damn it i was just at the dealer today too, forgot to ask them about it
