Originally Posted by 98altima
Sorry but i dont think that it would be that easy. and it sure as hell dont take 4k to do a complete swap, besides why spend 4k when you could buy a turbo kit for the altima for 3k
Keep in mind, as much as a KA turbo will make more power, it will cost a lot more than 3 grand. You need to consider how many miles are on the motor and what needs to be changed on the inside. Those internals are not for a turbo.
The SR20DET is designed for a turbo since the factory would not go make a motor for a turbo and leave junky internals. These motors are built to handle the turbo. For cheap speed this is the best swap rather than turbo'ing a KA which might need a rebuild and proper fuel system.
And on an Altima or 240, it is only about 4k to do a proper motor swap. Call around to some speed shops. Frankenstein honda swaps only cost 4-10 grand depending on the swap. the K series engine in a new civic being the most expensive of swaps.
You should really do some research if you plan to turbo your Altima.
-Good Luck
