Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Thread Tools Search this Thread
Old 05-29-2004, 02:31 PM   #1
n8s95gsx
Thrust berrings?
Has anyone had the joy of crankwalk and replaced the thrust berrings? i need a place that sells them? any info?
n8s95gsx is offline   Reply With Quote
Old 05-29-2004, 04:14 PM   #2
JoeWagon
Banned
JoeWagon's Avatar
Re: Thrust berrings?
Crankwalk means a rebuild, I don't know if you can get away with just trying to replace the bearings.
JoeWagon is offline   Reply With Quote
Old 05-29-2004, 04:46 PM   #3
joemathews
joemathews's Avatar
Maybe if you caught your car in the very earliest stage of crankwalk you could get away with just replacing the bearings...what other parts are replaced in the rebuild besides the bearings?
Steve Mathews
Eagle Talon
joemathews is offline   Reply With Quote
Old 05-29-2004, 08:52 PM   #4
n8s95gsx
well all that i know is that their is a ticking noise when i push the clutch in and its located in the front right corner of the engine. i have had no other problems that are associated with crank walk which is wierd i guess. does this mean it is at an early stage or what>?
Old 05-29-2004, 09:18 PM   #5
n8s95gsx
And is it possible to just have the thrust berrings replaced?
Old 05-30-2004, 12:39 AM   #6
guitarXgeek
guitarXgeek's Avatar
Send a message via AIM to guitarXgeek
One way to check for crankwalk (mind you, this is what I have been told, dont quote me) is to take your car to an empty parking lot, put it in reverse, and turn the wheel all the way to the left and see whether or not the clutch sticks. If it sticks, supposedly it's walked, or is almost walked. If anyone can confirm that this is a reliable way of checking for CW without dropping the oil pan, then please let me know!
guitarXgeek is offline   Reply With Quote
Old 05-30-2004, 01:30 AM   #7
kjewer1
AF - Advisor
Thats the most bizzare test for CW I have ever heard I had 3 motors crankwalk, never saw felt or heard anything unusual in the clutch. Go to the DSM section at www.racingknowledge.com and look for the sticky on crankwalk. I put tons of info in there, how to test, etc.
Replacing the thrust bearing will not remove whatever caused the bearing to fail in the first place, for what its worth
Kevin Jewer
POS RWD - 8.23 at 159
POS Mightymax - 10.8 at 124
kjewer1 is offline   Reply With Quote
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
